Truck shaking??? Help!!!
Discussion in 'Trucks [ Eighteen Wheelers ]' started by Trucker1921, Jun 11, 2021.
  1. Trucker1921
    Trucker1921 Bobtail Member
    11
    Dec 28, 2014
    Hello, I got a 2015 freightliner cascadia,I had a steer tire go flat on me on the highway,(did not pop)ever since then my truck has been shaking I replaced steer tires twice, Took it to the dealer they cant figure out what’s going on.I did notice it rides smoother with load on the trailer instead of empty trailer, also I’m feeling the shakes through my steering wheel an all over my truck? Any idea ??
  3. Dino soar
    Dino soar Road Train Member
    4,815
    27,071
    Dec 8, 2017
    From what I understand when Freightliner gets that shake it means that at least one tire is out of balance. Was your Rim damaged at all?
    When you had the tires replaced did they use balancing beads or something else to balance the tires?
  4. Trucker1921
    11
    Dec 28, 2014
    Rims look fine,They used that wheel balancing machine. My next step was to put a new rims on there just in case and see what happens from there. My cab is shaking as well with my steering wheel and it’s pulling me to the right I had an Alignment done as well.
  5. Heavyd
    Heavyd Road Train Member
    7,826
    6,276
    Feb 4, 2009
    Tire out of round, or out of balance. If the steering wheel shimmies back and forth, it is a steer tire. Wheels can be balanced, but not spinning true and be out of round to cause the shake/bounce. Need to jack up the axle, and spin the wheels as fast as you can and watch the top of the tire to see if it going up and down as it spins to show it is out of round. This can be caused by a bad tire to rim mount, or sometimes the wheel is not perfectly centered on the hub.
  6. GYPSY65
    GYPSY65 Road Train Member
    1,957
    5,265
    Nov 16, 2012
    SW FLA
    I’m not 100% but I think I’ve heard there is a mark also on tires that is supposed to be mounted opposite of the air stem??
  7. BoxCarKidd
    BoxCarKidd Road Train Member
    4,548
    6,641
    Aug 26, 2014
    I prefer to use a wood block on the floor. Do not turn the tire in the direction it can get sucked under the tire. You need a spinner and a looker. With some tires I will do this with the block square to the tire. Then offset to check the outer rib on on each side. Only jack up one side at a time. Jack in the center can allow the truck to rock and you are looking at a lie.
    Truck tires are not nearly as true as most folks would thank. About 1/8 inch out of round is probably pretty common and not a problem.
    Heavyd Thanks this.
  8. Heavyd
    7,826
    6,276
    Feb 4, 2009
    Yeah, the last shop I worked at had a great wheel spinner made by Hunter that could get the wheel up to highway speeds. I would pick out the stones and then spin her up and bring a tire crayon very close the tire tread surface so only the high spot would get marked. Stop the tire, relocate your high spot, loosen the wheel nuts, let it sink down and retry. This would cure 90% of shakes literally the first time.
  9. Caterpillar Cowboy
    Caterpillar Cowboy Heavy Load Member
    837
    607
    Nov 11, 2010
    Wyoming
    Also a the easiest time to polish your drives. The quality of the polish job is a direct correlation to your combined braveness and stupidity!
    Heavyd Thanks this.
  10. Johny41
    Johny41 Road Train Member
    1,192
    1,020
    Feb 10, 2011
    Ontario, Canada
    check cab mount bushings
  11. Trucker1921
    11
    Dec 28, 2014
    Hey guys I had in the shop again still no progress, I just don’t know how come nobody can figure this out lol. That website is a truck with similar situation as me.
