Truck shaking
Discussion in 'Questions From New Drivers' started by vusomujo, Sep 17, 2016.
  1. vusomujo
    vusomujo Light Load Member
    165
    13
    Jul 7, 2016
    Why does my truck shake when am stopped at a bridge.
  3. uncleal13
    uncleal13 Road Train Member
    3,797
    6,299
    Apr 9, 2009
    Humboldt, Sk
    Structural engineering. They are designed to have some movement in case of earthquakes or extreme winds.
    One in Edmonton at 170 st over the Yellowhead moves quite a bit when it's windy and lots of traffic bouncing over it. You can't see it, but you sure can feel it.
    dca and j_martell Thank this.
  4. Lonesome
    Lonesome Mr. Sarcasm
    11,685
    24,360
    Dec 15, 2007
    Northern Indiana
    It's afraid to cross. Freightliners are especially prone to this, but I've seen Macks, KW's, etc, also suffer this syndrome. Most trucks grow out of it, but there are extreme cases, where there is no cure to be found. Get 'er to the dealer ASAP, and explain that you have a truck with bridge crossing syndrome. If there is any hope for it, you will find it there.
    Good Luck, driver, keep us updated!
  5. dca
    dca Road Train Member
    6,834
    11,428
    May 31, 2011
    Earth
  6. Flatbedder73
    Flatbedder73 Medium Load Member
    464
    354
    Dec 30, 2012
    Langhorne, PA
    The subject line of this post was quite enticing....i could not scroll past it.
    windsmith Thanks this.
  7. windsmith
    windsmith Road Train Member
    7,296
    6,032
    Sep 2, 2011
    NEPA
    Fracking. Fracking causes the earth to shake.
    street beater and Lonesome Thank this.
  8. Driver91
    Driver91 Medium Load Member
    479
    287
    Jun 28, 2015
    Ain't you seen how big the motors are in these things. Can't help but shake
  9. KriegHund
    KriegHund Medium Load Member
    380
    473
    Nov 5, 2015
    On a hill south of heaven
    Try working under the deck when trucks are going across. Scared the poop out of me the first time. I was on top of the pier prepping for repairs on the rockers.
    RustyChops41 Thanks this.
  10. lilillill
    lilillill Sarcasm... it's not just for breakfast
    5,642
    13,472
    Nov 7, 2007
    Possum Booger, Alabama
    It is the bridge getting ready to fall in. Do you have your DOT mandated parachute handy? It should be with your triangles and fire extinguisher.
  11. lilillill
    5,642
    13,472
    Nov 7, 2007
    By the way, the Whitestone bridge in the Bronx has the same design as "Galloping Gertie"...
    You're welcome.
