Turbo help !!!
Discussion in 'Heavy Duty Diesel Truck Mechanics Forum' started by Nando85, Nov 11, 2019.
  1. Nando85
    Nando85 Bobtail Member
    43
    6
    Aug 9, 2017
    06 century 700k Detroit 14 liter 60 series .So 2 months ago I had my turbo go out it started leaking oil then finally gave up in a hill I replaced the cac,i did a 12.7 tune BG turbo was told that was best option ran for about 2 months notice alot power love it sounds better no more vpods,then I notice oil on the outside of the intake so I started putting everything apart and found oil again both sides I'm still under warranty going to replace it but does anyone know why so soon or if there is something I'm missing or had same problem thanks
  3. swaan
    swaan Road Train Member
    2,942
    4,374
    Jul 12, 2009
    BC canada
    Your air compressor, does it get its fresh air from the intake just before it goes into the turbo?
    Just wondering if its pumping oil. When compressor is not pumping into tanks it pumps into the air intake .
    If not it could just be a bad turbo also, it happens. How much boost you running with that tune in there.
    pushbroom Thanks this.
  4. Nando85
    43
    6
    Aug 9, 2017
  5. Nando85
    43
    6
    Aug 9, 2017
    Not sure on the turbo boost dont have a gauge but the turbo getting replaced because of warranty never thought about the air compressor .so my question is if the compressor is bad and leaking oil will it reach all way to the turbo bottom part??????
  6. starmac
    starmac Road Train Member
    6,639
    12,528
    Apr 11, 2019
    Fairbanks Ak
    I doubt it, the compressor is sucking there, the oil will be going the other way, never heard of a compressor doing that at all.
    Rideandrepair Thanks this.
  7. Rideandrepair
    17,550
    56,868
    Aug 8, 2015
    The compressor takes filtered turbo charged air in from the intake.Takes oil in via oil supply line, returns oil into front cover, where it bolts up.Brings coolant in and out using lines. Might push oil towards air dryer, especially if it’s old, might push air into crankcase, causing blowby, if it’s old, or has a broken piston ring. Anything’s possible, I guess, never heard of one putting oil into the intake.
  8. swaan
    2,942
    4,374
    Jul 12, 2009
    BC canada
    No no. I wasn't sure on the ddec5 engines if the compressor got its fresh air from intake on engine or from the intake tube going into the compressor of turbo. If it's like a ddec4 then no compressor will not cause this.
    More then likely your turbo is bad.
  9. Rideandrepair
    17,550
    56,868
    Aug 8, 2015
    Maybe it’s a dedec5? 2006, I had no idea they get intake directly from turbo. Learn something everyday
    swaan Thanks this.
  10. swaan
    2,942
    4,374
    Jul 12, 2009
    BC canada
    I'm not 100% sure either. Lol
    I thought I saw one that did one time.
  11. Roberts450
    Roberts450 Road Train Member
    2,237
    3,638
    Feb 6, 2016
    The new x15 and Im guessing the x12 or x13 pull that air for the compressor from a cast aluminum housing clamped onto the snout of the turbo. Took me a long time to get used to hearing the compressor through the air filters on my pete.
    Rideandrepair and swaan Thank this.
