Turbo let go
Discussion in 'Trucks [ Eighteen Wheelers ]' started by DDS, Sep 1, 2010.
  1. DDS
    DDS Medium Load Member
    519
    177
    May 20, 2008
    Toronto
    Made it 3/4 the way down the track Saturday night, hot wheel melted, failed and blew the cartridge right out of the exhaust housing. It's hanging by the oil lines! I was lucky the bearings stayed in, no oil leakage, or it would have burnt. Still ran a 15.9 on that run.:biggrin_255:
  3. DDS
    519
    177
    May 20, 2008
    Toronto
    Hers some more pics
  4. Far_Call
    Far_Call Medium Load Member
    453
    416
    Aug 21, 2009
    Australia
  5. Mr. Haney
    Mr. Haney Road Train Member
    2,693
    2,041
    Dec 17, 2008
    I'm gonna be an azzz...........:biggrin_25522:
    that's what ya get for boltin' a Cummins part to a CAT :biggrin_25523:
    now I know why you tried to call today..........I'll try to call ya tomorrow
    Sorry about the broken parts..........been there and done that and hate to see it
  6. Flying Finn
    Flying Finn Heavy Load Member
    972
    558
    Jun 22, 2010
    Ontario, Canada
    Pretty good carnage there. Anything downstream get any damage?
  7. DDS
    519
    177
    May 20, 2008
    Toronto
    That Holset HX82 worked well till now, just had it redone before the race, may have been a balance problem ( have to talked to the rebuilder). It would put out 55 psi and spooled well after 1800 rpm. No oil in the air to air, just compressor wheel parts.........
  8. pullingtrucker
    pullingtrucker Road Train Member
    1,185
    598
    Dec 21, 2008
    Fostoria, Ohio
    :biggrin_2556:#### DDS, now thats a little warm.:biggrin_25524: I gotta say you must of had a great run going when it happened. Get the thing fixed up and lets see so more runs.:biggrin_25525:
  9. Heavyd
    Heavyd Road Train Member
    7,826
    6,276
    Feb 4, 2009
    I have seen pieces blow backwards back up into the air filter. Change your air filters and check the pipes for debris. New air to air or are you cleaning it?
    Either she goes, or she blows!!!
  10. droy
    droy Heavy Load Member
    828
    160
    Jun 11, 2008
    Iowa, LA
    :biggrin_2555: WOW!!!!!! If it can't take it, it can't stay!
    Not near the $$$$ you're facing, but one of the orange hoses leaving the turbo, going to charge air split few days back. After finding problem, Saturday naturally, I stopped by KW dealer for new one. In a hurry to put it on, and continue with load, apparently I did not install it completely on, or maybe the penetrating oil I used for an "install aid" worked too good. After I thought I was finished, jumped back on I-10. Just as boost built up, new hose decided to abandon ship.......Sounded like a gunshot!!! I thought the four wheeler on side of me had shot my truck, apparently he thought the same of me, as we both hit our respective shoulders while standing on the brakes. Got lucky, didn't damage the hose; reinstall, and took off the tie wrap that had boost hose pinched off for good measure. Tomorrow I will pinch that bugger back,....if I still feel lucky.
    Hope yours works out!
  11. rollin coal
    rollin coal Road Train Member
    13,610
    27,974
    Mar 29, 2008
    TN
    wow your engine looks so clean you could probably eat off of it. sorry about your luck it brings to mind that saying i always hated to hear, you gotta pay to play.
