Turbo question
Discussion in 'Western Star Forum' started by n4ane, Dec 1, 2020.
  1. n4ane
    n4ane Light Load Member
    132
    59
    Aug 28, 2020
    So I supposedly have a big cam 400 motor that needs a turbo I have had some conflicting info. I typed in the part number off the turbo and google crossed it to a 3032075 and after getting it the parts is close looks to be bigger than what is on the truck using the number on the back of the block gives me a 3523415 and that part look correct am I going to have problems with using the 3032075? or am I better off ordering the 3523415? also what numbers on the pump tag tell me the info. 20201120_074936.jpg 20201120_074946.jpg 20201127_210039.jpg 20201121_152431.jpg 20201119_183402.jpg 20201019_185848.jpg
  3. RocketyMan
    RocketyMan Medium Load Member
    549
    337
    Jun 5, 2015
    It's great you posted pictures! But my eyes are not that good as I cannot read the stamping on the VIN, even when zoomed in.
  4. RocketyMan
    549
    337
    Jun 5, 2015
    If I had to guess...I think you have a Cummins BIG CAM IV, 444 HP
  5. n4ane
    132
    59
    Aug 28, 2020
    My apology's I didnt see the email where someone had replied last 6 of the vin is 922729
  6. Dino soar
    Dino soar Road Train Member
    4,813
    27,058
    Dec 8, 2017
    Well you really don't know what that engine is.
    That engine could have been rebuilt to a different CPL. Or it could be a completely different engine from the VIN number.
    Your best bet is to take the actual numbers off of the turbo that's on there and if it ran right like it should and everything work you should get the identical turbo and replace it.
    With engines that old you have no idea what anyone has done so that's really the best accurate thing to do without tearing into the engine.
    If the turbo looks different than what you have then either you got the numbers mixed up or they made a mistake and sent you the wrong Turbo.
    Rideandrepair Thanks this.
  7. RocketyMan
    549
    337
    Jun 5, 2015
    It's okay. I can help you out some. Good thing I have access to QuickServe.
    From the factory, it indeed is the Cummins BIG CAM IV. And obviously, anyone can change out anything.
    Your Engine S/N is: 11317957 (Got from your picture, but couldn't confirm original from vin s/n)
    Kinda interesting, the engine has a build date of '85. But your chassis is '88.
    Anyway, why would you not use the kit number off the turbo? Are you trying to rebuild the turbo? You weren't very clear...attached is a sub-component breakdown that mentions one of the P/Ns.
    You can buy supposedly new ones for about $700 and change
    NEW HT3B TURBO CUMMINS 3801598RX | Oregon Fuel Injection
