Turn signal problem
Discussion in 'Peterbilt Forum' started by Bobbyj, Apr 13, 2020.
  1. Bobbyj
    Bobbyj Bobtail Member
    I have a 2007 model 379 peterbilt and when I turn the right turn signal on the left one comes on in the rear in the right front one does not work turn the headlights on and I only have 3.3 volts going to the right low beam headlight left works fine headlight step on the brake and it cancels out the turn signal noise indicator If I unplug the front harness at the firewall everything works fine
  3. RocketScott
    RocketScott Medium Load Member
    579
    949
    Apr 10, 2013
    Kentucky
    Probably a bad ground somewhere. The current will look around for a path to take and cause things like the opposite turn signal to flash. Just had that issue with a trailer (well, the turn signal part, trailers don't have headlights)
    Look around the hood pivot, wires like to get pinched there
    062 Thanks this.
