Turn signal
Discussion in 'Freightliner Forum' started by Glenn West, Apr 1, 2017.
  1. Glenn West
    Glenn West Light Load Member
    88
    37
    Apr 22, 2016
    This is my first and likely last truck. I have to hold down my lever to get the turn signals to work. This normal or do I need a switch.
  3. tnevin225
    tnevin225 Road Train Member
    1,166
    1,601
    Jan 1, 2014
    Look in the fuse panel, there is signal relay that looks like this.[​IMG]
  4. Glenn West
    88
    37
    Apr 22, 2016
  5. boneebone
    boneebone Road Train Member
    2,297
    2,372
    Mar 13, 2009
    If you have to physically hold the lever up or down to get the turn signals to work, than your turn signal switch is defective.
  6. Glenn West
    88
    37
    Apr 22, 2016
    Yes, I have to. The left signal was the first to fail and now the right is also. Started this shortly after getting the truck. Does the steering wheel come off these like cars and pickups do? I have always on them just push up with knees and wack nut on post
  7. boneebone
    2,297
    2,372
    Mar 13, 2009
    If it's the Freightshaker Century in your picture, you will need to remove the plastic trim around the steering column and then you can R&R the Multifunction Switch/Lever.
    It should take about 15 min. or so to complete, or you could take it to the Freightshaker Stealership and they can fleece you for $150 labor plus parts.
  8. Glenn West
    88
    37
    Apr 22, 2016
    Thanks, I was just looking at it and thinking I could do that. I am slowly realizing these trucks are simpler to work on than cars/pickups.You can get to stuff easier.
  9. Glenn West
    88
    37
    Apr 22, 2016
    Ordered a aftermarket unit form Ryder today.
