Turning radius
Discussion in 'Heavy Duty Diesel Truck Mechanics Forum' started by spindrift, Jun 10, 2021.
  1. spindrift
    spindrift Road Train Member
    3,234
    12,915
    Dec 2, 2014
    Texas
    I'd like to improve the turning radius of my 2004 Pete by turning in the adjustment bolts that are on the backside of the steering hub assembly. Is there a science to how much you turn in the bolts or is it simply trial and error?
  3. ibcalm19
    ibcalm19 Road Train Member
    1,463
    2,435
    Nov 30, 2015
    Pennsylvania
    I forgot that mathematical formula I used for calibrating the turning radius. I'll tell you a secret trial and error when all else fails.:D:D
    spindrift Thanks this.
  4. Goodysnap
    Goodysnap Road Train Member
    3,767
    9,186
    Jul 12, 2017
    The left side will hit first. Check for tire clearance and adjust the left side first. Your actually adjusting the right stop bolt to set the left clearance. I ussually allow 1/2" minimum tire clearance from any object. Once set count the steering wheel turns and set the right side to match the left for same number of turns.
    Since your turning sharper you may have to reset the poppets inside the steering gear if find the steering still stops at the previous spots and will not assist to the screw stop. Consult steering service manual. A hard steering wheel pull against the stops ussually does the trick.
    RubyEagle and spindrift Thank this.
  5. Dave_in_AZ
    421,473
    Man that 05 KW mixer I was forced to drive had the turning radius of a guided missile cruiser.
    The first time I wheeled into the staging area of the plant I dang near crashed.
  6. Shawn2130
    Shawn2130 Heavy Load Member
    896
    1,897
    Sep 20, 2015
    Southern Ontario
    We drive a 1990 long nose international dump truck that takes a lot of 3 point turns
    still a fun truck to drive
    BoxCarKidd Thanks this.
