Any sugestions on a good 12 volt tv that will not fade out when viewed from lower or higher angels. I bought a skyworth 15.6" but had to return it. I could not view it from sleeper bed unless I was sitting up. Thank you for any info.
tv
Discussion in 'Freightliner Forum' started by gmpire, Apr 29, 2012.
I built a "ball mount" for my LG 15" flat screen. I had the same problem so I fixed it with a ball mount so I could swivel it up or down or left to right depending where I was viewing it from. Works well because the TV is so light. I found the ball mount at True Value Hardware, but for the life of me I can't remember what is was designed for. It just happened to be workable for my TV.
Might give you an idea on how to solve your issue. Most flat screen LCD TV's are going to pose the same problem. -
It's because it's LCD. Any LCD is going to have the same issue.
thank you 4 the info.
