Twin turbo
Discussion in 'Heavy Duty Diesel Truck Mechanics Forum' started by Pup97, Jan 8, 2018.
  1. Pup97
    Pup97 Light Load Member
    191
    263
    May 30, 2016
    What would be a good twin turbo set up minus the accert set up. Just wondering if anyone runs a twin turbo cat that is not the accert chargers.
  3. KVB
    KVB Heavy Load Member
    877
    2,875
    Jun 30, 2012
    Antrim Diesel used to do compound turbos, not sure if they still do.
    Compound turbo setups?? Anyone done one??
    Maybe you can find more info here.
  4. SmokinCAT
    SmokinCAT Road Train Member
    1,773
    1,488
    Oct 20, 2010
    Hillsboro, OH./ Adrian, MI
    Are you planning on going above 800 hp at the tires?
    SAR, spsauerland and Dave_in_AZ Thank this.
  5. Aron
    Aron Bobtail Member
    33
    16
    Nov 13, 2016
    I didn’t Go away Faith twin set up on my 3460 cat I went with a PDI setup out of Ogden Utah bigger turbo, exhaust manifold and their program puts 675 to ground and gained a mpg
  6. Aron
    Aron Bobtail Member
    33
    16
    Nov 13, 2016
    Sorry autocorrect didn’t go with a twin setup
  7. spsauerland
    spsauerland Road Train Member
    4,296
    10,891
    May 31, 2010
    West Harrison, In
    I think the OP is wanting to do this to a B model. Not sure how is planning on fueling and timing. Wish he would post application and what he is trying to accomplish. Waste on over the road truck imho.
    SAR Thanks this.
  8. SmokinCAT
    1,773
    1,488
    Oct 20, 2010
    Yes, I agree. The 7Fb has an amazing amount of exhaust energy thanks to low compression, it is really surprising at the turbos they can spin, problem is that the 7FB still has aluminum pistons and they will be the limit.
    E model Cat man and SAR Thank this.
  9. spsauerland
    4,296
    10,891
    May 31, 2010
    West Harrison, In
    I think keeping intake air temps down would be a huge problem. Like Smokin Cat said, if aluminum piston it will not live long before cracking. Would have to drive it with super light foot. I still say try the 177148 BW.
    SAR and wore out Thank this.
  10. Pup97
    191
    263
    May 30, 2016
    Is the 177148 off like a e model or something?
  11. spsauerland
    4,296
    10,891
    May 31, 2010
    West Harrison, In
    Aftermarket replacement for 3406E. It is wastegate style. Much newer technology than old 3406C model OR6501.
    SAR and Oxbow Thank this.
