Typical Leased on Tractor Only
Discussion in 'Ask An Owner Operator' started by Swift09, Aug 19, 2019.
  1. Swift09
    Swift09 Light Load Member
    77
    106
    Jul 4, 2019
    What are ball park numbers if you lease on to a company and own a truck only? All scenarios are welcome. Thank you
  3. Wespipes
    Wespipes Road Train Member
    1,037
    1,816
    Jul 14, 2019
    The range varies greatly!
  4. Cabinover101
    Cabinover101 Heavy Load Member
    726
    1,166
    Jul 28, 2019
    $1 - $200,000
  5. stuckinthemud
    stuckinthemud Medium Load Member
    620
    3,063
    Oct 20, 2013
    iledbett, fishonron and Wespipes Thank this.
  6. Swift09
    77
    106
    Jul 4, 2019
    Thanks for the replys. I guess I should be more specific. What percentage of the gross are you getting? And of what the company takes what does that cover typically? Say you get 70 to 75% what are you responsible for and what does the company cover? I've seen 87% but I'm sure that's having truck and trailer both. Thanks again!
  7. Wespipes
    1,037
    1,816
    Jul 14, 2019
    Landstar takes 35% so you make 65% that's using their trailers
    Most other outfits will take 15% you make 85% that's you using your own trailer. Basically they just dispatch you
    stuckinthemud Thanks this.
  8. starmac
    starmac Road Train Member
    6,639
    12,528
    Apr 11, 2019
    Fairbanks Ak
    It depends on who you leae too, some companies furnish all insurance, except bobtail, and workmans comp. Base plates ifta, hut . some that just charge 0 to 15 % may just furnish the name on the door, and you find your own freight.
    Some will have at least some direct freight, others will just use brokers.
    Some will either rent or sell you a trailer, some won't
    Some will be a set mileage, while others will be a percentage.
    Unless there is a lot of drop and hook involved, I would have a hard time renting a trailer from most carriers.
    The percentage or fees they charge, will buy or rent a trailer else a much better deal.
    77fib77 and stuckinthemud Thank this.
  9. Ridgeline
    22,723
    123,063
    It doesn't matter.
    The reality is that what they give you should be based on what they get.
    If you have a company that only produces low rates, then it doesn't matter what they take ... you get a percentage of cheap rates.
    Pick a company that produces money.
  10. GreenPete359
    GreenPete359 Road Train Member
    2,245
    5,400
    Oct 21, 2017
    Driving my recliner
    Back it down. He hadn’t even made it that far yet.
    Op. It varies widely. The carrier should cover both liability & cargo insurance. They may or may not cover tags & ifta.
    It’s all in the contract that you sign, every company has their own. What you need to do is figure your numbers out (some good leads for that have already been given). Then decide how in depth you want to go with your own back office.
    If you are not a paperwork and numbers kind of guy, i suggest finding a company that takes care of everything for you. They will pay the lowest percentage.
    If you can pull your own weight in the office, find a company that puts the responsibilities on you.
    Wespipes Thanks this.
