I've got a single axle with Low Air Leaf suspension. The frame rail heights above floor vary by 5/16" when measured at the air bags. Floor is level. Tire pressures are the same. Doesn't sound like much, but it is about 1" from side to side on my 8'4" flatbed. Has anybody added a spacer above or below the air bag on the low side to correct this? Or any other ideas? Thanks.
Uneven frame height.
Discussion in 'Peterbilt Forum' started by JTS51, Oct 8, 2011.
check the height on the front of truck, could be a weak spring on one side raising the opposite side on the rear. or just a bent frame rail.
It could actually be only a shock, hard to believe but when a shock starts to get weak it sits much lower than the rest because it can't hold the oil pressure , check the shock in the lowest corner -
Put spacers between the front axle and the spring to level the front, and the rear should take care of itself. Almost every truck sits lower on one side in the front, which affects the rear.
