Unknown Vibration
Discussion in 'Heavy Duty Diesel Truck Mechanics Forum' started by 21blaumeyer, Jun 3, 2024.
  1. 21blaumeyer
    21blaumeyer Bobtail Member
    10
    6
    Apr 11, 2024
    Central MN
    I have a 1998 Intl 9400. About 3 weeks ago i noticed a vibration that goes through the whole truck. It starts about 55-60 mph. While driving it’s constant but will go away for about 1 minute or when you hit a bump. I just had the truck aligned, new output bearing on the transmission, and some other things. I have Toyo street tires with centramatic balancers, and cheap Chinese Kapsen drive tires. I’m trying to figure out what it could be. I’m thinking tires.
  3. MRMTRANS
    MRMTRANS Medium Load Member
    406
    440
    Apr 28, 2015
    A steer axle that is towed out will lead to a vibration that comes then disappears as you increase your speed. I've heard starts at 45-55 mph then goes away 5-10 mph faster. It will be worse the more the kingpins are worn. I went thru this 10 years ago. Another factor with my truck was a slightly twisted frame. You know a frame us twisted when the cab looks like it is leaning one direction. You can put a level across the frame rails and the put it along the bottom of the cab to be more sure. Worn kingpins and a twisted frame apparently was sone of the cause for my truck. I personally do my own alignments and know the tow in was correct. It wasn't until I replaced the kingpins that the vibration went away. BTW, a steer axle needs to be towed in 1/16" when sitting on the ground after pulling forward. On an alignment rack, a little more because the wheels "relax" on the plate the tires rest on as they can turn.
    21blaumeyer and 5UG Thank this.
  4. Diesel Dave
    9,481
    31,149
    Jan 20, 2010
    Hesperia, Ca.
    If you have air suspension, check the height. Adjust accordingly to specs.
  5. Diesel Dave
    9,481
    31,149
    Jan 20, 2010
    Hesperia, Ca.
    Check the slip through driveshaft also, try pushing it up and pulling it down for excessive play. The teflon on the splines will wear if it’s not lube.(Sometimes they get missed).
    21blaumeyer Thanks this.
  6. envycarz
    envycarz Bobtail Member
    Jun 4, 2024
    bad balance. Do not get cheap tires ever again
  7. Diesel Dave
    9,481
    31,149
    Jan 20, 2010
    Hesperia, Ca.
    Been there done that, and they weren’t cheap tires either.
  8. Miro1988
    Miro1988 Bobtail Member
    6
    May 26, 2024
    Can you advise any shop who can do those things? Just bought truck had have this kinda problems , living in south Florida and these guys know not more than me about 3 axle
    think I got trust angle problem
  9. 21blaumeyer
    10
    6
    Apr 11, 2024
    Central MN
    I learned that lesson they wear weird and inconsistent. Next set I’m gonna invest in and get a set of centromatics.
  10. 21blaumeyer
    10
    6
    Apr 11, 2024
    Central MN
    I grease the whole rig every 7-8k about every 3 weeks and purge the u joints. It ended up being the output bearing took it to a shop and they did synchros and the bearing but no race. I didn’t learn that until 5,000 miles later and the tranny went out. Turns out the mechanic wanted to leave early that day and didn’t replace the race. Cost me 4,500 in tow, hotel, parts and labor.
    Diesel Dave Thanks this.
  11. OldMainiac
    OldMainiac Light Load Member
    187
    1,887
    Aug 2, 2024
    Never should have accepted the repair, ALWAYS install a new race with a new bearing!
