Used chains anyone?
Discussion in 'Flatbed Trucking Forum' started by HardwareHyena, Apr 6, 2022.
  1. HardwareHyena
    HardwareHyena Light Load Member
    138
    138
    Nov 17, 2011
    Depew, NY
    Need 8. Or can you make your own with pins and hooks from the Home Depote' that french name place?
    CAXPT Thanks this.
  3. kranky1
    kranky1 Road Train Member
    2,253
    8,855
    Sep 16, 2015
    Ontario, Canada
    Chain you find there may or may not be transport certified chain. Check or it could be expensive. If the chain and hook are marked Transport 70 or G70 you’re good to go. If the hook isn’t stamped the same as the chain the DOT won’t count that one at the scale.
  4. Hayfieldmn
    Hayfieldmn Light Load Member
    158
    239
    Sep 10, 2016
    You can make your own as long as it's heavy enough for what you need, grade 70 is most common. I wouldn't buy used, I snapped a 1/2 chain the other day and it's only 3 years old. It was on a light load as well. Best of luck.
  5. AModelCat
    164,498
    As mentioned above, they've got to be Grade 70 and yes you absolutely can buy the appropriate chain and hooks and assemble them yourself.
    jamespmack and CAXPT Thank this.
  6. Arctic_fox
    4,505
    25,401
    Sep 16, 2016
    You can assemble your own sure. I prefer to buy the studded reinforced type though. They cost a lot but if im throwing chains their about to get a workout.
    MOBee, CAXPT and HardwareHyena Thank this.
  7. HardwareHyena
    138
    138
    Nov 17, 2011
    Depew, NY
    I was thinkin'. Could be bad but just buy any ol' chain and Dremel a grade 70 on the metal so it says grade 70?!
  8. beastr123
    beastr123 Road Train Member
    2,947
    24,180
    Jan 2, 2014
    Moose Jaw SK CAN
    You go right ahead and when a weakened chain breaks due to an accident and the DOT inspects your load and hits you with a seperate fine for each chain broken or not and suspends your licence on the spot for too many CSA points. You can be proud of the 10 bucks per chain you saved.
  9. kranky1
    2,253
    8,855
    Sep 16, 2015
    Ontario, Canada
    If you want to do about every 3rd link of the chain. Differs by manufacturer how may are skipped, but the chains are embossed full length.
  10. AModelCat
    164,498
    Creates a stress riser in the steel. Not a good idea.
    MOBee, CAXPT and beastr123 Thank this.
  11. HardwareHyena
    138
    138
    Nov 17, 2011
    Depew, NY
    Good point. ☝️
    Just don't see chains breaking unless you done already messed something else up, driving related, and that's not fault of the chain anyhow but...
