VAC gauge
Discussion in 'Heavy Duty Diesel Truck Mechanics Forum' started by hoffa660, Dec 7, 2019.
  1. hoffa660
    hoffa660 Bobtail Member
    30
    16
    Feb 14, 2015
    Can anyone tell me what this gauge is for? And what numbers it should run? It's in a 2001 Freightliner classicXL with a 1994 N14 Cummins celectplus engine 525hp. I've looked everywhere and I can't find anything on it and what it should read.
  3. Roberts450
    Roberts450 Road Train Member
    2,237
    3,638
    Feb 6, 2016
    Air filter restriction gauge. Should read 0-5” of H2O under hard pulls and if it starts going over 20 the filters are starting to get pretty plugged up.
    Goodysnap Thanks this.
  4. hoffa660
    30
    16
    Feb 14, 2015
    Oh ok yeah under hard pulls it's been getting up to 8, the turbo usually gives between 23-27psi depending where my rpms are. Air filters were replaced in March got 74k on them. What's the usual life span of them in dual breather setup? I run kck to Oregon and back dedicated
  5. Roberts450
    2,237
    3,638
    Feb 6, 2016
    My 389 with a 600 x15 wont pull my restriction gauge over 1 and I have 237,xxx and two years on the factory installed filters. My 15” donaldsons I think are bigger then the filters on your classic, so if you’re pretty much just on the big road like me then you should get a year+ out of them.
    pushbroom and spsauerland Thank this.
  6. Final Drive
    Final Drive Road Train Member
    1,573
    2,505
    Jan 21, 2015
    I thought that the Celect Plus was introduced in 1997....
  7. Slowpoke KW
    Slowpoke KW Road Train Member
    1,170
    12,827
    Dec 7, 2015
    OK
    What type of line runs to it? It could also be a fuel filter restriction gauge.
  8. Roberts450
    2,237
    3,638
    Feb 6, 2016
    Fuel is normally in inches of Hg not H2O.
  9. Final Drive
    1,573
    2,505
    Jan 21, 2015
    Could be a air filter service gauge..
    dibstr Thanks this.
  10. dibstr
    dibstr Road Train Member
    1,308
    932
    Sep 10, 2010
    It is
