Verizon connect eld
Discussion in 'Oilfield Trucking Forum' started by Oilfieldtrucker123, Mar 7, 2019.
  1. Oilfieldtrucker123
    Oilfieldtrucker123 Bobtail Member
    Feb 25, 2019
    8
    Thanks Received:
    Anyone on here using the Verizon connect eld? If so how do I get the 5th line on my logs for the oilfield exemption?
  2. RyanZ
    RyanZ Bobtail Member
    Dec 31, 2018
    Thanks Received:
    4
    ND
    I run Verizon Connect for OTR not OilField but I'm guessing you'd have to call into your Verizon rep or call the help line to have them push out an update. Here's the number: 1-844-617-1100
    Oilfieldtrucker123 Thanks this.
  3. RyanZ
    Dec 31, 2018
    Thanks Received:
    4
    ND
    It looks like your fleet admin should be able to select the Federal - Oilfield Exemption and you should be set to go.
  4. Oilfieldtrucker123
    Feb 25, 2019
    8
    Thanks Received:
    Thanks fellas
