Vibration at certain speeds
Discussion in 'Heavy Duty Diesel Truck Mechanics Forum' started by Kenllah, Nov 12, 2018.
  1. Kenllah
    Kenllah Light Load Member
    226
    113
    Nov 17, 2017
    I have an international 9400 1998. Twin screw. I'm getting vibrations on both sides of 50 mph. It's a hard , tractor shaking vibration. Not in the steering wheel. Hardly noticeable if not loaded. Bobtail, nothing. Before this came on I replaced the rear gears due to pinion bearing play. Then the passenger rear leaf spring was broke, replaced. All tires replaced. Rear passenger air bag replacement due to not inflating to proper height. All tires shaved and balanced at alignment shop due to this vibration. After that didn't fix it I rotated the tires, no difference. I'm at a loss at this point. I'm leaning towards new shocks on the drive axles. Any advice would be appreciated. I really thought it was the air bag causing the problem.
    Rideandrepair Thanks this.
  3. Kenllah
    226
    113
    Nov 17, 2017
    Also checked the drive line and replaced one u joint due to slight play.
  4. Hulld
    Hulld Road Train Member
    2,884
    6,568
    Oct 19, 2015
    Upstate NY
    Sounds like it could be a possible drive line angle problem.
    The drive shaft angle changes from bob tail to loaded.
    AModelCat and Rideandrepair Thank this.
  5. Kenllah
    226
    113
    Nov 17, 2017
    I thought the leveling valve adjusted ride height regardless of load. I actuate the valve by hand and it works as advertised. The rod on the leveling valve is non adjustable. It is not damaged or disconnected in any way.
    ALSO, this happens if in gear or neutral, coasting or pulling.
  6. Kenllah
    226
    113
    Nov 17, 2017
  7. SteerTire
    SteerTire Road Train Member
    1,414
    2,347
    Nov 5, 2018
    Behind the wheel
    Several things come to mind. I note you said tires balanced at alignment shop. But was there an alignment (3 axle) done?
    Or there could be bearing issues.
    You really need a competent mechanic to do a ride along. Often times things can be sorted out quickly when that happens. Or at the very least, it will give a good mechanic a starting point.
  8. tommymonza
    tommymonza Road Train Member
    4,519
    12,849
    Sep 10, 2013
    S.W. Florida
    The fact that it does it loaded or unloaded and coasting or pulling is interesting.
    My 97 9300 I just bought has a heck of a vibration you can feel through the shifter.
    I know the steers are shot even though they look good.
    The vibration from them is getting transferred through the truck and is shaking the motor and transmission.
    Thinking my motor and transmission mounts are shot .
    Can you feel the vibration change loaded unloaded through the shifter?
  9. Goodysnap
    Goodysnap Road Train Member
    3,771
    9,195
    Jul 12, 2017
    Your issue is in fact in the driveline or angles as @Hulld suggests. Measure and set the suspension ride height to factory specs. From there I would recommend you pull the main drive shaft assembly and have it rebuild and balanced at a reputable driveline shop.
    While less likely in the intermediate shaft between the axles, probably not a bad idea to pull that one for a shakedown as well.
  10. Rideandrepair
    17,550
    56,868
    Aug 8, 2015
    The rod isn’t adjustable but the arm on ride height valve is. Two bolts 1 stationary 1 slotted. Get proper height info loosen both just enough to move set and tighten. Check axle torque rods ( bushing bad?) Spring bushings.Some Times after replacing a u joint if Drive shaft is installed at 180 degrees off from original locations a new vibration will appear.Have to take driveshaft out and reinstall 180 degrees with new straps and bolts. It’s a long shot.Excessive ride height will cause a chatter in gear shift / trans while accelerating, Excessive low height causes grinding when coasting in gear. Other than Bent rim or Excessive wheel bearing play.
  11. Rideandrepair
    17,550
    56,868
    Aug 8, 2015
    And check the motor mounts too
