Vibration at low end torque
Discussion in 'Heavy Duty Diesel Truck Mechanics Forum' started by stayinback, Jun 17, 2019.
  1. stayinback
    stayinback Road Train Member
    3,911
    8,257
    Jan 24, 2014
    chicago,il
    I just replaced a worn out carrier bearing, Now I have a vibration at low rpm's in 4th thru 7th gear- doesn't matter loaded or empty-Loaded its more significant. Once reaching normal operation 1500-1600rpm,its fine and smooth.
    Checked for play in yokes-everythings tight.
    I have some seepage at rear of transmission pinion.
    Any ideas? I did NOT have a vibration before I changed carrier.
  3. Cam Roberts
    Cam Roberts Road Train Member
    1,621
    1,938
    May 13, 2018
    if no play in out put shaft than it is fine
    Dave_in_AZ and Rideandrepair Thank this.
  4. Navtech
    Navtech Light Load Member
    62
    43
    May 9, 2019
    I would check and make sure a weight didn’t get accidentally knocked off the drive line during the carrier replacement
  5. Cam Roberts
    1,621
    1,938
    May 13, 2018
    doesnt make sense in his post at all though. its not driveline speed related at all. He says its rpm related. Only thing rpm related would be motor balance. Better check the balancer. If its throwing that much vibration where you can feel it, good by crank and good by motor
    Rideandrepair Thanks this.
  6. Navtech
    62
    43
    May 9, 2019
    I was just going off more the “didn’t have vibration before I replaced the carrier” comment
    Rideandrepair and FlaSwampRat Thank this.
  7. stayinback
    3,911
    8,257
    Jan 24, 2014
    chicago,il
    Its not Crank Related-Motor mounts are good- Coming from the Trans- Output shaft- Im gonna pull the back half off and check bearings.
    Only feel it in the seat-maybe a touch on the wqheel , ONLY UNDER TORQUE CONDITIONS-
  8. Deere hunter
    2,118
    10,004
    Aug 5, 2017
    Shallowater Texas
    Your driveline yolks have to be lined up when you put it back together you may have got it off just a little bit and that will make your driveline vibrate !!
  9. lwlevens
    lwlevens Medium Load Member
    623
    427
    Feb 9, 2018
    Install the old carrier bearing if you still have it and see what happens.
  10. Rideandrepair
    17,548
    56,853
    Aug 8, 2015
    Remove driveshaft and turn it half way around and re install. They should always be marked and Re-installed the same way. It can only go 2 ways.
    Dave_in_AZ and Dino soar Thank this.
  11. Rideandrepair
    17,548
    56,853
    Aug 8, 2015
    Also you probably know, new straps and bolts, and torque proper. I learned the hard way broke bolt off in yoke, had to replace it. Made Me a believer. Lol
    stayinback Thanks this.
