vibration
Discussion in 'Freightliner Forum' started by MJ23, Nov 1, 2014.
  1. MJ23
    MJ23 Bobtail Member
    10
    Nov 1, 2014
    I have a 2011 Columbia that has a bad vibration only when pulling a load and traveling at highway speed. Thought it may be the transmission but it runs fine well unloaded. Anyone have experienced the same.
    magoo68 Thanks this.
  3. Freightlinerbob
    Freightlinerbob Road Train Member
    2,234
    1,316
    Jan 15, 2012
    West Coast B.C.
    Is it coming through the dashboard on the left side?
  4. damutt
    damutt Road Train Member
    1,126
    370
    May 6, 2013
    is the vibration coming from the drive tires? is it coming in /out at a certain speed? is i gear related?
  5. MJ23
    MJ23 Bobtail Member
    10
    Nov 1, 2014
    Its coming from the floorboards up through the peddles.
  6. MJ23
    MJ23 Bobtail Member
    10
    Nov 1, 2014
    Coming in at speeds over 50
  7. Freightlinerbob
    2,234
    1,316
    Jan 15, 2012
    West Coast B.C.
    I'd have a really close look at the rear engine mounts. Especially the left side. It's hard to see and harder to replace, but they are a common fail point on this chassis. Look for signs of the rubber de laminating from the steel. If you ever do a clutch, change them regardless.
  8. MJ23
    MJ23 Bobtail Member
    10
    Nov 1, 2014
    Bob the vibrations only happens when its loaded these mounts would only be affected under these conditions.
  9. Freightlinerbob
    2,234
    1,316
    Jan 15, 2012
    West Coast B.C.
    OK, then it's probably not the engine mounts.
    Thinking out loud here:
    1) When is the last time the truck was greased? A dry driveline will give off vibrations.
    2) tire PSI? Tires inflated higher than they need to be for the weight they're carrying, will cause vibrations/ rough ride. As will cheap tires.
    3) #1 u joint- is it in good shape? A spun cap will cause vibration.
  10. damutt
    1,126
    370
    May 6, 2013
    tire(s) out of round?
    flat top Thanks this.
  11. Freightlinerbob
    2,234
    1,316
    Jan 15, 2012
    West Coast B.C.
    When my engine mount broke, the vibration only became obvious under heavy engine load.
