Vin check help
Discussion in 'Western Star Forum' started by Rasim, Mar 23, 2017.
  1. Rasim
    Rasim Light Load Member
    96
    16
    Jan 24, 2014
    i am looking to buy a western star and frommy understanding i believe that some of you guys can help withthe vin report.
    The milage on the truck dash says 750k it is a 1999 western star with a red top n14 engine.
    This is the vin: 2WKEDDJJ1XK955988
    Email me [email protected] or post on thread thanks.
  3. SAR
    SAR Road Train Member
    2,756
    36,654
    Nov 26, 2011
    ND
    Here is some info that I can help with. This is off the Gates web sight. Just enter your VIN here.
    http://www.gates.com/catalogs-and-r...business-applications/vin-decoder/vin-decoder
    Manufacturer
    Western Star Trucks Inc.
    Make Western Star
    Model Year 1999
    Model 4900E
    Engine Manufacturer Cummins
    Engine Series N14, NTC, Formula, PT
    Engine Capacity L6, 14.0L (855 CID)
    Fuel Type Diesel
    Vehicle Type Truck
    Cab Type Conventional - Constellation
    Chassis Tractor
    Drive Line Type 6 x 4
    Brake System Air
    GVWR Class Class 8: 33,001lbs & over
    Country Canada
    Assy. Plant Kelowna, BC, Canada
  4. Rasim
    96
    16
    Jan 24, 2014
    I really appreciate your help and this is good info. Any way i can look into service history especially milage. Id like to know when was it last serviced and what the original milage is. Maybe he swapped the engine? Or maybe he reached 1,750,000 miles? Not sure if western star will show the "1" for the million or will it reset back to zeros on the dash.
  5. Rasim
    96
    16
    Jan 24, 2014
    Anyone else?
  6. SAR
    2,756
    36,654
    Nov 26, 2011
    ND
    Maybe have the place where your looking at the truck plug into the ecm and see if the miles match up with what shows up on the odometer. Otherwise I'm not sure how much more info you can get, maybe find out from previous owner where it was serviced at or work done at a shop. Maybe Cummins might have records of engine work done but if it was done outside of cummins it probably wont get reported. Maybe someone else can chime in and help you. Good luck
    Rasim Thanks this.
  7. Cetane+
    Cetane+ Road Train Member
    1,304
    882
    Sep 29, 2013
    Albany, NY
    For a running $15000 truck it doesnt matter if its 750 or 1.7m. If the truck looks good, then thats that.
  8. Rasim
    96
    16
    Jan 24, 2014
    Yes but propper diagnosis still needs to be taken.
  9. Animosus
    Animosus Heavy Load Member
    730
    2,892
    Dec 7, 2015
    SE Wyoming
    It is too old for we as dealers to look any service history up on it. In fact because it was pre-Daimler we really can't do much for you.
  10. AModelCat
    163,701
    Kelowna built. Back before Daimler got their hooks into them and turned them into junk.
  11. Rasim
    96
    16
    Jan 24, 2014
    Thanks anymosus...NorthernMechanic, so daimler built is good?
