VLN 760 rolls back at start, Need help
Discussion in 'Volvo Forum' started by Aliz15, Oct 27, 2019.
  1. Aliz15
    Aliz15 Bobtail Member
    Dec 22, 2015
    15
    Thanks Received:
    Its a volvo VLN 2014 with I-shift.
    I am having problem as when on stop or red light, i release brake pedal & push throttle., truck rolls back & i get check transmission at next stop but no code.
  2. Socal Xpress
    Dec 6, 2014
    1,855
    Thanks Received:
    1,958
    Los Angeles, Ca
    How many miles? Has the clutch ever been replaced?
    You really need to have it diagnosed properly with Vcads.
    KB3MMX Thanks this.
  3. Aliz15
    Dec 22, 2015
    15
    Thanks Received:
    got this truck a month back. clutch feels strong, good pull, rpm not fluctuating, smooth shifting.
  4. Aliz15
    Dec 22, 2015
    15
    Thanks Received:
    Any ideas people?
  5. 05vnl670
    05vnl670 Light Load Member
    Feb 17, 2013
    165
    Thanks Received:
    60
    By any chance you using manual mode when you pull up to stop. It happen to me couple times when i stooped at lights and i was driving in manual mode and forgot to down shift gears, but i didn't see a ck transmission message.
  6. Aliz15
    Dec 22, 2015
    15
    Thanks Received:
    No. am in auto mode. downshifts good. feels like hill assist kind of thing.
  7. nasriza
    nasriza Road Train Member
    Feb 1, 2013
    2,407
    Thanks Received:
    2,077
    Chicago, IL
    is the hill assist enabled or does it work . possible something wrong with hill assist but it would not say check trans anyway, what kind of code is pulling up when check trans is coming on.
    KB3MMX Thanks this.
  8. Aliz15
    Dec 22, 2015
    15
    Thanks Received:
    tried with a scanner but no codes.
    its 2014 VLN 670, i don't see any button to enable or disable hill assist. is there suppose to be one?
  9. MMAL
    MMAL Bobtail Member
    Oct 31, 2019
    Thanks Received:
    I have similar problem I put it into drive but can’t get any acceleration same goes for reverse. But once I shut it down in on few times with pedal pulled up. It seems to work sometimes changing from Netrual to reverse it feels a little rough not always.
    15 Volvo vnl
