Voltage drop when engine under load
Discussion in 'Heavy Duty Diesel Truck Mechanics Forum' started by frankdtank, Mar 30, 2021.
  1. frankdtank
    frankdtank Light Load Member
    83
    49
    Sep 27, 2018
    04 Sterling with Cat C-12. For the last week or so my voltage just been all over the place, no starting or dead battery issues. Replaced the alternator and no real change. It will sit at high idle (900 rpm) at 13.5V but when the engine is placed under a load it starts to drop to as low as 12.4 V depending on how hard the engine is working. When I get over an incline and roll downhill with the engine being able to "relax" the voltage immediately starts climbing to above 13 V, but it drops back down as soon as it's pulling again.
    Also after startup I need to rev up the engine (never had to do this) to get it to start charging.
    This afternoon I replace the batteries and jump cables but as far as I can tell on the yard it's still doing the same thing. Any thoughts ? Thanks
  3. Jaebo74
    Jaebo74 Medium Load Member
    433
    1,864
    Feb 4, 2021
    I had this happen to me once, it was a bad ground strap from the engine to the frame. It might also be a bad ground from the frame to the batteries.
    Hope this helps
    BoxCarKidd Thanks this.
  4. dkooi
    dkooi Bobtail Member
    8
    4
    Mar 28, 2013
    Grab some jumper cables and ground the alternator directly to the battery. If your problem goes away it's a grounding issue. Likewise if you have a grounding problem on the cab you can hook it directly to your grounding lug on the firewall. This will help you diagnose and get you moving till you can do the proper repair.
    Jaebo74 Thanks this.
  5. frankdtank
    83
    49
    Sep 27, 2018
    Interesting, I'll definitely try that. Thanks.
  6. Kw1999
    Kw1999 Bobtail Member
    4
    Hello friend wore you able to fix the problem? I'm struggling with same issue
  7. frankdtank
    83
    49
    Sep 27, 2018
    Never fixed it. I monitored the voltage with and independent meter from the cigarette lighter, which was normal. Also the truck ran fine and since was sold.
  8. Mr Bob
    Mr Bob Light Load Member
    269
    84
    Mar 17, 2015
    test voltage at the alternator post and at the battery post.
