Voltage guage erratic while idle
Discussion in 'Heavy Duty Diesel Truck Mechanics Forum' started by BoyWander, Sep 15, 2019.
  1. BoyWander
    BoyWander Road Train Member
    1,411
    2,125
    Jul 22, 2011
    So I was just laying in bed, had just parked maybe 30 mins prior, with truck off, when the battery warning came on. I had just put new batteries in 2 months ago and have had no issues.
    I turn the key, digitial read out is showing 11.6 volts. Starts fine. Then it goes up to 13.9-14.0 where it normally should be.
    I sit there and watch the guage slowly go from 14 down to 13.3, then all the way up to 14.4 and then back down again.
    I cleaned the wires when I installed the new batteries, and put them all back in the order they were in before.
    Truck is a 2017 volvo with 234k miles.
    Thinking the problem is a loose wire or voltage regulator in the alternator. Or maybe the belt is going bad.
    I can't stand sleeping with the truck running so I'll just shut off the battery box tonight. Not much food in the fridge, probably wont go bad in 8 hours. Don't need to charge anything.
    Likely culprit?
  3. BoyWander
    1,411
    2,125
    Jul 22, 2011
    I think I fixed it.
    When I shut the engine back off, guage read 11.6 usually it holds at 12.5-12.7 when off.
    3 of the bolts holding the wires/cables on the batteries were a little bit loose. I tightened them up.
    Guage then showed 12.7
    Started engine and volts showing 14.0 like it normally does.
    Holding steady.
    I guess this post will now be buried for years, but hopefully someone else will come along and find it helpful.
    Step 1 should probably be
    "Check for loose wires"
    daf105paccar, uncleal13 and sealevel Thank this.
  4. uncleal13
    uncleal13 Road Train Member
    3,797
    6,296
    Apr 9, 2009
    Humboldt, Sk
    I did that myself recently.
    I have a Maxwell Engine Start Module. As time went on it turned the engine over slower and slower. But the test light and voltages all showed normal.
    One weekend I finally took all the wires off and found the wire that goes to the starter had a loose connection and welded itself to a washer.
    Worked great after that.
    BoyWander Thanks this.
