Voltage Issues 1981 peterbilt 359
Discussion in 'Peterbilt Forum' started by 81 peteman, Nov 1, 2016.
  1. 81 peteman
    81 peteman Bobtail Member
    im getting 24 volts in cab to everything lights ect... cant figure out why. Im not getting any 12 volt at all and no power to right hand side of breaker box,
  3. AModelCat
    163,805
    Check your series-parallel switch. It might be stuck. Try and give it a smack with a rubber mallet. See if that helps.
    Old school 362 and BUMBACLADWAR Thank this.
  4. BoxCarKidd
    BoxCarKidd Road Train Member
    4,541
    6,619
    Aug 26, 2014
    Then when you figure out that is your problem, which it surly is, buy a new 12V starter. Through all that 12-24V stuff in the trash. It is a good update for about the same money.
    AModelCat Thanks this.
