Voltage problem
Discussion in 'Volvo Forum' started by JackCo, Dec 21, 2020.
  1. JackCo
    JackCo Bobtail Member
    4
    Dec 21, 2020
    voltage started out at 13.1 (usually 14.4) then after idling for about an hour or two voltage is at 15.1 and climbs 0.1 about every 20 minutes. If I give it gas it's goes to 16.0 pretty quickly and stays there or higher. Just got a new alternator (they said and it looks like new, though haven't had the best Ryder experiences). This is the issue I brought it in for but they "couldn't duplicate" the issue; any ideas?
  3. Socal Xpress
    1,855
    1,958
    Dec 6, 2014
    Los Angeles, Ca
    Need more information. Year engine transmission. Does the truck have a battery cut off switch? Typically they cause a voltage drop.
  4. 6cuda6
    6cuda6 Light Load Member
    259
    176
    Oct 9, 2020
    Also do you have an inverter or a battery combiner (something to charge the APU battery)?
  5. uncleal13
    uncleal13 Road Train Member
    3,797
    6,299
    Apr 9, 2009
    Humboldt, Sk
    On Freightliner there is a five amp fuse for the alternator voltage sense wire, when it blows I get high voltage like you.
    I don’t know if Volvo has similar setup.
