Volvo 2020 check engine Fault code p009b. Any thoughts?
Discussion in 'Volvo Forum' started by virgilantes, Apr 8, 2022.
  1. virgilantes
    virgilantes Bobtail Member
    6
    4
    May 14, 2021
    Volvo truck 2020 check engine fault code p009b. Any thoughts ? Thank you.
  3. Another Canadian driver
    Another Canadian driver Road Train Member
    1,181
    4,266
    Nov 14, 2021
    ALBERTA
    Will it help?
    Please let us know.
    P009B Fuel Pressure Relief Control Circuit/Open
    The PCM monitors the fuel pressure regulator and opens the fuel pressure relief valve to return excess fuel back to the fuel supply system. Code P009B is set by the PCM when the Fuel Pressure Relief Control Circuit is open. What is the severity of this DTC? The severity of this code is normally moderate based on the specific malfunction.
    virgilantes and noworrez Thank this.
  4. virgilantes
    6
    4
    May 14, 2021
    True! Volvo dealer changed the valve for a plug, changed the fuel pressure sensor, reset the system . Everything is fine. Thank you.
