Volvo 2020 , code 256000. ?
Discussion in 'Ask An Owner Operator' started by virgilantes, Apr 25, 2022.
  1. virgilantes
    virgilantes Bobtail Member
    6
    4
    May 14, 2021
    Message on the screen: engine coolant level criticaly low ( not true). Changed the coolant level sensor, nothing changed.
  3. Six9GS
    Six9GS Road Train Member
    1,473
    3,697
    Dec 3, 2012
    Yuma, AZ
    My 2019 had the same critically low fault. It was low, but hardly to the point I'd call critical. I dumped 2, normal sized 17 oz. Water bottles into the reserve tank and got rid of the warning. Then went to the nearest truck stop, got a gallon of coolant and dumped about half of it in to fill up the reserve tank.
    virgilantes Thanks this.
  4. BobO1176
    BobO1176 Light Load Member
    141
    205
    Oct 29, 2021
    Now that you have that code and you are still consuming coolant, your EGR cooler has probably failed. I had to replace mine at 125,000miles after getting that code and continued coolant consumption for a couple of weeks before it could be diagnosed.
  5. TallJoe
    TallJoe Road Train Member
    7,490
    16,273
    Apr 12, 2016
    Chicagoland
    In my case, when the coolant level was good and it was showing "coolant level critically low", even after replacing the sensor, it turned out to be the plug itself (to which you put the sensor in) that went bad. So I wired in a new plug and the problem was solved.
    However, since your truck is 2020, it would seem a little odd for those plugs to start giving out so early, so it still might be something else.
    86scotty and Siinman Thank this.
  6. 86scotty
    86scotty Road Train Member
    4,677
    12,833
    Aug 27, 2017
    Appalachia
    True but I would still test it. Lots of new or nearly new failures in parts these days. My wife's new ride had a coolant leak at 3,000 miles.
