Volvo Air Suspension Parameter
Discussion in 'Volvo Forum' started by Bakhtiyar, May 7, 2020.
  1. Bakhtiyar
    Bakhtiyar Bobtail Member
    4
    Hello Guys
    anyone does know how can I increase lifting bags for rear axles of volvo FH12 2005 by TechTool ?
    Thanks
  3. Snailexpress
    2,675
    6,069
    Apr 28, 2014
    Rocky
    If your truck has electronic control suspension. You can change height sensor calibration but it will change driveline and axle angle. Why you need to change ride height?
    Bakhtiyar Thanks this.
  4. Bakhtiyar
    4
    Thank you for your reply
    Really driver want to change it because when I return the rear air bag to zero level it will come down more for this reason he want to hieght small millimeters
  5. Snailexpress
    2,675
    6,069
    Apr 28, 2014
    Rocky
    I don't know Volvo FH but you was warned about drive line and pinion angles. First will be destroyed radial springs in clutch, then pinion seals and bearings. Drive tires, fuel mileage, driver fatigue. Drive line vibration literally will destroy whole truck.
    Bakhtiyar and KB3MMX Thank this.
  6. Bakhtiyar
    4
    Thanks for your advice...
  7. KB3MMX
    KB3MMX Road Train Member
    3,075
    2,596
    Dec 29, 2014
    Orrstown, PA
    In other words... Leave it the #### alone lololol
  8. Snailexpress
    2,675
    6,069
    Apr 28, 2014
    Rocky
    Is this particular truck single drive axle or tandem? And leveling valve is one for both axles or there two of them on each axle?
  9. Bakhtiyar
    4
    It is single drive axle with one leveling valve
