Volvo D12D compression and balancing test
Discussion in 'Volvo Forum' started by bravoo67, May 4, 2012.
  1. bravoo67
    bravoo67 Light Load Member
    253
    35
    Mar 15, 2012
    Brooklyn NY
    Hi my engine VED D12D 465HP sounds like it misfires, I did compression and balancing test with VCADS and compression test showed all cylinders with around 95% compression but balancing test showed on one injector -60% (negative) ..
    Ive changed this injector and it still shows around the same -60%
    all other injectors are very close to the level +/- 5-10% just the second cylinder is different.. -60%
    Why this injector shows such a big difference or is it normal??
    Thank you for any info
  3. Pablo-UA
    Pablo-UA Road Train Member
    7,604
    1,642
    Oct 11, 2010
    Borispol, Ukraine
    -60% is bad injector. What is the fuel rate? Run fuel consumption check. 1.2-2L/h at idle is normal. Over - bad injectors, low power, lover 1l/h - black smoke, bad fuel milage
    bravoo67 Thanks this.
  4. bravoo67
    253
    35
    Mar 15, 2012
    Brooklyn NY
    Fuel consumption is around 1.8 to 2.2 .. most of the times 2.2 so I have to replace this injector again
    Could it be bad connection or circuit on injector cables?
    There are no faults on the dashboard
  5. bravoo67
    253
    35
    Mar 15, 2012
    Brooklyn NY
    Could it be bad connection or short circuit to the ground somewhere on injector cables?
  6. Pablo-UA
    7,604
    1,642
    Oct 11, 2010
    Borispol, Ukraine
    belive me, it is bad injector... to be sure you can swap two injectors....
    really, change it, and do not forget to program trim code and zero ballancing values
    KB3MMX and bravoo67 Thank this.
  7. bravoo67
    253
    35
    Mar 15, 2012
    Brooklyn NY
    Ive changed injector but didnt program anything, have to check vcads where and how to do that :)
    Thank you so much for your help!!
  8. bravoo67
    253
    35
    Mar 15, 2012
    Brooklyn NY
    Pablo could you please explain how to program trim code and zero balancing values??
    I spoke with my mechanic and he doesnt know how to do that :(
  9. Pablo-UA
    7,604
    1,642
    Oct 11, 2010
    Borispol, Ukraine
    use TT ore VCADs pro. Use operation Parameter programming. Find EECU (MID 128) and injectors control list. Enter trim code. Save settings.
  10. bravoo67
    253
    35
    Mar 15, 2012
    Brooklyn NY
    Will tell him.. Thank you very much!!
  11. noxcape
    noxcape Bobtail Member
    19
    May 29, 2012
    chicago, IL
    thank you for info
