Volvo D13 P20e892 Code
Discussion in 'Heavy Duty Diesel Truck Mechanics Forum' started by ApexMaster, Mar 14, 2019.
  1. ApexMaster
    ApexMaster Bobtail Member
    15
    Hi guys I am having hard time solving this one. Code P20E892 and few other codes, but this is my primary concern. see image for active codes. after doing little research i came to conclusion the DEF fluid pump is not priming or pumping fluid, or Reluctant pressure sensor not working. any help would be much appreciated.
  3. Oneel998
    Oneel998 Bobtail Member
    22
    6
    May 21, 2019
    okay, the cluster isn't where you wanna look for your faults. there are different level of faults. The cluster SHOULD only throw a MIL light. Engine/Aftertreatment will throw the check engine light on your dash. So, first, without being hooked up to the truck, you PROBABLY need a DEF pump. When you turn your truck off you should hear it running. If you don't its possible a DEF pump failure happen OR you have a rub wire. Its about a 50/50 on either because no one thinks its important to run the wire harness to correct way by your tank.
  4. vanik
    vanik Bobtail Member
    i have same Code P20E892, DEF pump replaced still no luck! what was the problem with your truck?
  5. vanik
    Code P20E892 who can help?
  6. Maxgdl28
    Maxgdl28 Bobtail Member
    You need a new def pump and service regeneration
  7. RoadtoEmmaus
    RoadtoEmmaus Light Load Member
    100
    44
    Apr 20, 2014
    I have been searching for answers, if anyone had it fixed, please, do tell.
    I have the same code plus P110286.
    Many say the pump. But I clear the codes and turn the engine on. When I turn it off, I hear the def pump, followed by the ticking of the def injector walking back the fluid.
    After about 15 min driving, the codes come back. I only get about 3/4 engine power with threats of 5 mile derate. When I shut the engine off, NO sounds of pump or ticking.
    Again, if I clear codes, I get full power and hear the pump and tickng after shut down. Only if codes are present the pump wont activate.
    So how could it be the pump if its working as long as codes are clear.?
    Also the P110286 is not listed in any of the Volvo d13 troubleshooting guides. But when I go online, I found some say its a bad AHI module.
    Why isnt it in the book? As110286?
    Could the bad ahi module affect the Def pump? Not sure.
    Also, why is it called Reductant pressure? Are we talking of the DEF fluid? Or air? Why not just say low def fluid pressure
    Any answers would be appreciated.
    Thanks
  8. JB7
    JB7 Heavy Load Member
    974
    1,700
    Dec 13, 2022
    Laurel, MD
    I have fault code SA 17 DTC P20E892 and code MID 140 PSID 45 FMI 9 on a 2016 volvo vnl 860. The first fault code is in (justanswer.com)
    2016 D13 ACM fault | TruckersReport.com Trucking Forum | #1 CDL Truck Driver Message Board (thetruckersreport.com)
    Read posts 8 and 10 on the Truckers Report link. Mentions batteries, connections and grounds. Also def filter.
  9. RoadtoEmmaus
    100
    44
    Apr 20, 2014
    Thanks..i read all that a few days ago. None of it answers any of my questions.
    The issue is that most people dont come back to this forum and post what the fix was.
    Thanks tho
  10. RoadtoEmmaus
    100
    44
    Apr 20, 2014
    Well I'll answer myself...
    Bad ahi module and def pump.
    I bought after market and installed myself. Also replaced the coolant lines that go to DEF doser. They literally just cracked and fell off while i was tinkering. Lost some coolant before I got a bucket.
    Codes gone for now.
    JB7 Thanks this.
