Volvo ECM blocking mismatch
Discussion in 'Heavy Duty Diesel Truck Mechanics Forum' started by TiredTech, Apr 13, 2021.
  1. TiredTech
    TiredTech Bobtail Member
    4
    Feb 23, 2021
    2014 Volvo VN. Updated Trans ECU. Installed new clutch. I cannot calibrate the clutch because either the transmission or the laptop cannot see engine RPMs. The tach in the dash works though. I'm banging my head in the wall here. I cannot revert back to the old transmission programming because our tech tool apparently does not have access on the back end.
    Help? All of my j1939 lines have checked out. Does anyone know the exact routing of the engine speed signal?
  3. QUALITYTRUCK
    1,819
    1,783
    Jun 14, 2009
    romulus,mi
    This is going to sound crazy. Humor me. Do you have good battery voltage? Did you install driveshaft?
    spsauerland and baha Thank this.
  4. TiredTech
    4
    Feb 23, 2021
    Driveline is in. All programming is done with a charger hooked up.
    25(2)+2 Thanks this.
  5. russelltrue11
    russelltrue11 Bobtail Member
    Did you find the problem?
