Volvo Mirrors
Discussion in 'Trucks [ Eighteen Wheelers ]' started by Cummins600, Jan 2, 2012.
  1. Cummins600
    Cummins600 Bobtail Member
    26
    8
    May 18, 2011
    Pa
    Hey everyone,
    Have a 2000 Volvo 770 that I would like to replace the mirrors in. My question is how do you take the mirror off the door? I see torx bolts that go through the hinge and then into the mirror. Also, how do you disconnect the wires so I can avoid cutting them. Thanks.
  3. nckid
    nckid Light Load Member
    183
    56
    Nov 11, 2008
    williamsburg,va
    Try and pull the mirror wires up to get to the connector if u cant do that u may have to take the door panel off to get access which is no biggie.
    Cummins600 Thanks this.
  4. Pablo-UA
    Pablo-UA Road Train Member
    7,604
    1,642
    Oct 11, 2010
    Borispol, Ukraine
    There is sealed connector by AMP with small pins there. Press on small lever to unlock, push it in and then pull out
