Volvo rough ride
Discussion in 'Volvo Forum' started by Igor9113, Apr 14, 2020.
  1. Igor9113
    Igor9113 Bobtail Member
    13
    5
    Apr 14, 2020
    Hi, I have a problem with my volvo vnl 2007. The truck rides very rough especially when loaded, but when empty too, and When hit bump or crossing bridge or railroad truck bouncing making me crazy. After I Changed all 6 shocks and 2 cab shocks, also king pins front leaf springs bushings and rear springs too alignment, truck rides little bit better but it’s still same problem when crossing bridge or railroad or any hole on road I feel how rear bouncing and feels rough. Anyone has any idea how to fix this problem ?? Thanks
    truckdriver31 Thanks this.
  3. boneebone
    boneebone Road Train Member
    2,297
    2,372
    Mar 13, 2009
    Did you replace the front cab mount bushings, worn out ones will make your cab ride choppy?
    Also check that your leveling valve height is set correctly for your cab and your rear suspension.
    A incorrect height setting will cause the air springs to be overly inflated giving a rough ride.
  4. Igor9113
    13
    5
    Apr 14, 2020
    Yes I did
  5. Igor9113
    13
    5
    Apr 14, 2020
    How to calculate to set correctly valve height for cab and frame ?
  6. boneebone
    2,297
    2,372
    Mar 13, 2009
    Depending on how your truck is spec’d out, it’s best to contact the Volvo Stealership with your VIN number and they can tell you how and where to measure so you can correctly set the ride height.
    PE_T, truckdriver31 and Igor9113 Thank this.
  7. truckdriver31
    6,998
    8,363
    Sep 18, 2013
    are tires good. low rubber will cause a sucky ride super fast.
  8. LoneRanger
    LoneRanger Road Train Member
    3,695
    9,605
    Jun 3, 2018
    Shocks? Check and see if the shocks are oily. If yes then new shocks.
    PE_T Thanks this.
  9. Igor9113
    13
    5
    Apr 14, 2020
    Good year in very good condition
  10. Igor9113
    13
    5
    Apr 14, 2020
    All shocks replaced week ago
  11. TheLoadOut
    TheLoadOut Road Train Member
    2,412
    11,559
    Nov 6, 2019
    Check the cab leveling valve directly under the back of the sleeper, right in the center. If the arm falls off the little ball it clicks into, which wears out after time, your cab air bags aren't even filling up. Just zip tie it up if that's the case or replace if you need. That will definitely change your ride.
    stillwurkin Thanks this.
