Volvos?
Discussion in 'Ask An Owner Operator' started by Trucker327, Feb 15, 2019.
  1. Trucker327
    Trucker327 Light Load Member
    176
    20
    Dec 24, 2017
    How good are Volvos? Either with there own engine or the cummins enginee..which is better to have? Is it true that they have a lot of electrical problems? What are the most common problems?
  3. Ridgeline
    22,719
    123,190
    they are the same as any other truck, nothing to get excited about.
    Bean Jr. and 86scotty Thank this.
  4. TallJoe
    TallJoe Road Train Member
    7,490
    16,273
    Apr 12, 2016
    Chicagoland
    Nothing further from the truth for someone who spends half his life in it. Only those who may only own it but don't use it can think like that. NOT just a tool --- hell of a lot more!
  5. RustyBolt
    RustyBolt Road Train Member
    2,073
    3,335
    Feb 21, 2015
    Bement, IL
    If I were going to buy a Volvo, I would opt for the Cummins. And for really only one reason. You can find a shop (and parts) that works on Cummins on every street corner, so to speak. With a Volvo engine, you may get lucky from time to time and find a shop that can work on it. But most often, it's going to be headed to the nearest stealership. Of course, while under warranty, you'd probably be headed to the stealership anyway.
    I should add that this doesn't apply to every repair job on a Volvo. The diesel engine is fairly well the same regardless of manufacturer. But the DEF and auto trans etc are not.
    Trucker327 Thanks this.
  6. TallJoe
    7,490
    16,273
    Apr 12, 2016
    Chicagoland
    Comfy, quiet and ergonomically best. Good for tall and XXXL people. Engines are like with any other trucks - a matter of luck and maintenance schedule.
    86scotty Thanks this.
  7. parkwayautotransport
    parkwayautotransport Bobtail Member
    15
    6
    Jun 5, 2017
    MN
    We have a few volvos and our biggest issue is that if we do need a part or any maintenance done otr apparently no one has volvo parts or some mobile services will even refuse to work on it because its a volvo. otherwise our volvos are our best kept trucks-very basic issues.
  8. 201
    201 Road Train Member
    12,764
    26,262
    Apr 16, 2014
    high plains colorado
    Meh, Volvo's get a bad rap, but I guess they're ok. Lot's of guys like them, but lots of guys liked the Freightliner cabover too. I only drove the older ones, that were highly generic. They all have basically the same parts underneath, so to say one truck is better mechanically than another is silly. Comes down to what cab you like best in trucks.
  9. Ridgeline
    22,719
    123,190
    I get what you are saying but my post is the truth.
    its JUST a tool, it depends on what matters to you that makes it a decision to buy but it is only a tool.
    You don't date it, you don't take it to a hotel after a movie and drink, you don't marry it.
    It is a tool.
    You get overly emotional about it then maybe there's problem, it is just like a hammer or a drill ... a tool.
    If you spend half your life in it, that's a long time to spend in the cab of the truck. I think most of the trucks I own are seven years and newer, so ...
    A Volvo is just like any other truck, there is NOT much difference between it and a mack or a KW or a pete or a WS, they are all the same, they move the same, they break down the same, they get the same mileage and they haul the same weight.
    They are no better than the next one.
    Because it is just a tool.
    If you want to discuss the what really matters, it isn't the engines or the electrical but what Parkway alluded to - the dealer/parts supply is limited in some areas and good service is hard to find.
    I own macks, I love my macks and I have had volvos that were bought through fleet purchases, they gave good service but even mack dealers would not be able to fix them when they gave me problems.
    Bean Jr. Thanks this.
  10. Confused
    Confused Light Load Member
    224
    270
    Sep 22, 2009
    somewhere else
    I've owned 3 Volvos in the past, first one was a 1999 770. Detroit 60 series motor, put a million miles on that truck and only thing it was in the shop for was a turbo and regular maintenance.
    2nd one was a 2008 780 with Volvo d16 had a wrecker follow me constantly ( jk ) because it was always in the shop, it was one thing after another going wrong with that truck.
    3rd was a 2012 vnl 300 .d 16 with ari sleeper. Replaced injectors and cups with updated ones, that was only problem i had with that truck.
    Biggest problem I had with Volvo, was the dealerships not having mechanics who knew what they were doing, and the time it took before dealers could get your truck in to work on it, plus they never had the parts.
    I now have a 2019 Western Star and from first time i had to turn on ac while in Florida it didn't work, tried to get it into a shop from Florida to Tennessee and none could get me in for at least a week or two.
    So at the end of the day it doesn't make one bit of difference what you buy, if you can't get the #### things worked on .
    Truckermania Thanks this.
  11. Tombstone69
    Tombstone69 Road Train Member
    1,010
    1,346
    Dec 20, 2018
    Jersey shore
    I don't know if they're a good truck or not, I've never driven or owned one , but I do know two things, they don't hold their resale value and there's an awful lot of them out there rollin'.
