W9 Front Suspenion
Discussion in 'Trucks [ Eighteen Wheelers ]' started by shoesw9, Jan 25, 2011.
  1. shoesw9
    shoesw9 Bobtail Member
    11
    pinckard,al
    I have an 04 W900L that has started to ride ruff. The front has 7 leafs packs, is there a conversion kit so I could install a monoleaf? Airride? Both? Just put new kingpins,shocks and tires on, next step are springs and shackles. Just want to know if I could make it better before I buy stock parts.:biggrin_2558:
  3. Superhauler
    Superhauler TEACHER OF MEN
    12,209
    100,735
    Jan 30, 2010
    keep stroking.
    i would make sure the shocks are the right ones and see if one or both the tires are not defective if it started when you did this.
  4. shoesw9
    11
    pinckard,al
    It's been progressively getting worse, the springs are wore out along with the shakle pins.
  5. canuck in da truck
    canuck in da truck Road Train Member
    4,352
    2,601
    Aug 6, 2010
    western pa
    i would try the shocks/spring pins and bushings--springs them selves seldom wear out--break yes --i have driven w-9's with well over 1 million miles and still original springs
  6. DL550CAT
    DL550CAT Road Train Member
    1,427
    1,483
    Oct 18, 2009
    Waynesburg, Pa
    I would make sure the spring pins will take grease and are not froze up.
  7. shoesw9
    11
    pinckard,al
    Yea DL550 the pins are the problem. I want to make it ride better with better parts thats all. Has any one installed air ride on the front?
  8. Diesel Dave
    9,635
    32,555
    Jan 20, 2010
    Hesperia, Ca.
    When I had my COE K100, I put on a set of "KONI" adjustable shocks and it was the smoothest riding COE I ever drove. My buddies all had conventionals at the time and when they rode with me they couldn't beleive how smooth it rode.
  9. Superhauler
    12,209
    100,735
    Jan 30, 2010
    keep stroking.
    instead of airride get a set of horton roller bearing shackel pins it will make a big difference.
  10. shoesw9
    11
    pinckard,al
    The roller shakles ride that well, I will look into them thanks.
  11. Pfuse
    Pfuse Light Load Member
    119
    52
    Aug 18, 2006
    La Crosse, WI
    Contact Scott Cornett at Lite Flex for a set of composite springs. I'm not sure if they make them for the W9, but it would be worth checking on.
    email
    scornett at liteflex dot net
