Wabco EasyStop Sensor
Discussion in 'Trucks [ Eighteen Wheelers ]' started by Mountain_Dweller, Aug 22, 2018.
  1. Mountain_Dweller
    Mountain_Dweller Bobtail Member
    29
    12
    Oct 18, 2014
    Good Evening,
    I have a trailer with the Wabco ABS system, 2 sensor 1 modulator (I think) configuration. Had a bad YE/2 speed sensor, changed it out with a brand new sensor and still getting a Code 6. Tried plugging in another brand new sensor same thing, swapped the sensors at the computer and the code followed (code 4, YE/1). Any ideas? Do these things ground through the spider or something?
    Thanks!
    -Nathan
  3. Snailexpress
    2,675
    6,068
    Apr 28, 2014
    Rocky
    Check the tone ring. The tone ring should be clean and sensor should touching ring tooth. If wheel hub bearing is loose this will happen almost 100% Readjust wheel bearings by manufacturer manual.
