Wages for a local driver
Discussion in 'Questions From New Drivers' started by stacks, Oct 11, 2025.
  1. stacks
    stacks Road Train Member
    1,546
    850
    Oct 27, 2011
    Emerald Isle
    Just interested to know for a new driver that had paid his way through CDL school , and obtained his or her own CDL what are realistic wages , for a new driver driving local with no touch freight .
  3. plant
    plant Heavy Load Member
    862
    806
    Sep 21, 2012
    Los Angeles, CA
    High teens low twenties. Local no-touch is probably the lowest paying class A work that exists.
    OldeSkool Thanks this.
  4. stacks
    1,546
    850
    Oct 27, 2011
    Emerald Isle
    Well pulling intermodal for some of the larger carriers could pay upwards of 1 K a week for New drivers. The reason I mentioned No touch not All drivers have The same physical Ability
    77fib77 Thanks this.
  5. Thrasher28
    Thrasher28 Road Train Member
    1,246
    3,549
    Aug 12, 2021
    Bowling Green, KY
    Cowan, Ryder, MTS, etc. are all in the 60-70k range where I live for super basic no-touch, day cab runs
    stacks Thanks this.
  6. Grumppy
    3,233
    11,401
    Dec 11, 2010
    West Monroe, La
    Wages are different in different regions of the country. Where are you?
    To get a job with most companies, you'll need at least one year experience and two years for most good companies. Do you have any verifiable driving experience?
    lual and OldeSkool Thank this.
  7. BrothaTrucka513
    BrothaTrucka513 Medium Load Member
    512
    982
    Aug 30, 2020
    Your gender doesn't matter to me, but you started the sentence using the pronoun "his" then later switched to using "his or her " by the end. Are you currently transitioning? I believe in equal wages for the both of you... whomever you decide to be
  8. tscottme
    tscottme Road Train Member
    Local jobs usually have more applicants than jobs so pay doesn't have to be high to keep trucks occupied. Number of jobs vary wildly in different locations.
    lual, stacks and BrothaTrucka513 Thank this.
  9. BrothaTrucka513
    512
    982
    Aug 30, 2020
    Factual. I had a guy try to coerce me into accepting two dollars less than he initially promised during the driving test. I chose not to work there
    stacks and wulfman75 Thank this.
  10. BillMot
    BillMot Light Load Member
    83
    152
    Oct 7, 2025
    Atlanta, GA
    For a new driver fresh out of CDL school and running local no-touch freight, a realistic starting wage is usually around $20 to $25 an hour. That works out to roughly $1,000 to $1,300 a week if you’re working full time. Some areas or companies might pay a bit more, especially if demand is high.
    The nice thing about no-touch local runs is you get steady hours without having to handle freight yourself, so it’s a good way to get experience, build your record, and then move up to higher-paying routes if you want. Expect pay to grow fairly quickly as you gain experience and a clean record.
    stacks Thanks this.
  11. stacks
    1,546
    850
    Oct 27, 2011
    Emerald Isle
    None yet I was thinking of paying through CDL school as I have over 20 years experience outside the USA , but I have drove in the USA as I worked In western Canada for 18 months for a reefer outfit and my region was the lower USA primary hauling Beef loads out of Alberta
