Walking floor pump psi
Discussion in 'Tanker, Bulk and Dump Trucking Forum' started by abyliks, Nov 9, 2022.
  1. abyliks
    abyliks Road Train Member
    4,107
    9,657
    May 2, 2010
    ludlow MA
    So, 2 year old wet kit on my truck, pretty sure it’s a 32ish gph pump which runs the bucket and the low bed easily, one thing I do remember when ordering parts specifically says “there’s no ####ing way im ever hooking this truck to a walking floor”
    so here’s I am, curious what the psi difference of the pump is, and whether I should swap to a dual stage pump, also, my return goes to the tank, don’t the higher psi pumps return to the pump THEN the tank?Not going to be an every day thing, but local company was asking about pulling their trailer In the busy season when possible, so I’m wondering if my pump will run it or if I should upgrade, thanks
    Oxbow Thanks this.
  3. #1 Kenworth
    #1 Kenworth Light Load Member
    105
    91
    Sep 21, 2012
    New England
    Long time ago my friend put a pump system on for his walking floor. Price was right so he did it. When we went to pump the demo off it was so slow. Granted it was winter and we thought the load was frozen. Was close to a hour to get it off. They checked the system and found the cheap price was because it was for a dump body not walking floor. I think the gph was like half of what was needed.
  4. Cat sdp
    Cat sdp . .
    21,294
    76,122
    Apr 8, 2012
    Orion's Belt
    3000 psi for a walking floor I think…..just don’t top your cylinder out on the dump trailer and you’ll be fine……
  5. lester
    2,956
    8,078
    Jan 2, 2012
    NW, Iowa
    I can't speak for what you need to run a walking floor trailer but I run a big 60gpm pump at pretty good pressure. My return goes through a cooler then to the tank. How would returning to pump then tank even work?
    RockinChair Thanks this.
  6. abyliks
    4,107
    9,657
    May 2, 2010
    ludlow MA
    i don’t quite remember the psi of the pump, I’ll have to get the number off it this afternoon but I’m pretty sure it was a premco pump. Don’t know if I want to change it if it’s only a 2/2500 psi
  7. RockinChair
    RockinChair Road Train Member
    5,353
    14,279
    Feb 19, 2012
    Lubbock, TX & thereabouts
    I would ask the head mechanic for that company what flow rate and pressure their trailers require.
    lester Thanks this.
