WANTED ASAP
Discussion in 'Flatbed Trucking Forum' started by dberset, Jan 12, 2020.
  1. dberset
    dberset Light Load Member
    75
    35
    Jan 12, 2020
    Hey guys. I have a 2012 manac flatbed conestoga and I’m looking for straps. Manac had a brainfart and designed a trailer you can’t hook straps to under the side rail(not rub rail). Because it’s a conestoga I cannot hook to the rub rail. The dealer we bought it from said at the time they had 600 cases and I thought for sure they would last a while. I was wrong, they’re out. Kinedyne made the originals proprietary for manac and stopped producing them a few years ago. I live up in the frozen tundra of upper Michigan and when they get some age they start sucking up water and freeze in the winter. The ones I have are in decent shape just wet and frozen all the time.
    If anyone can help me out I would greatly appreciate it.
    Thanks
    stwik and cke Thank this.
  3. Ruthless
    Ruthless Road Train Member
    9,164
    90,981
    Aug 28, 2010
    The City.
    put a tie bar on the hook side. It’s just a 2.5”x 1/4” piece of flat stock bolted to All the crossmembers.
    Tada. Now you can use flathooks, those ones you got, or chain ends (which would also work with most product for what you are looking to do now).
    SAR and kylefitzy Thank this.
  4. dberset
    75
    35
    Jan 12, 2020
    I’ve thought about that, and it would be easy but on a conestoga you have rubber flaps to seal the opening between the rub rail and deck in the bottom side. I haul multiple loads a week that are multi stop and having the hook I have makes it easy to unload something only on the hook side. If I use flat hooks doing what you say I’d have to pull the whole strap or multiple straps over roll em up and toss em back over because you can’t feed the hook back through the rubber flap(one way, top down only). With my hooks I just leave slack off the winches and unhook the hooks and let em hang over the edge. being still attached at the winch the lift driver just needs to make sure the hooks don’t get caught on any edges or the lift itself and pull out from underneath the straps. We have a transcraft with a conestoga also and it’s set up the normal way with flat hooks and the flat bar underneath but my trailer is quick and easy with my hooks.
    I may very well have to bolt the flat bar underneath if I cannot find a source for straps. I’m gonna give it a try and see what I can find.
  5. brsims
    brsims Road Train Member
    5,296
    6,522
    Aug 8, 2009
    Meadville, PA
    From the pictures, you also appear to have the tracks for J-Hooks? Also called J Plates? I used those all the time on my Rietnouer connie, and still use them on my Rietnouer side kit set up.
    You can get the at Tarpstop or other tarp shops. Or any place that sells and installs conestogas. Be prepared for some price sticker shock, but they do last a good long time and you can use them for flat hook straps or chain end. I use them for chains and binders on coils all the time, they work great.
  6. Ruthless
    9,164
    90,981
    Aug 28, 2010
    The City.
    I have a couple conestogas. And do multi stop 3 runs a week. Tie bar. Flat hook.
    Peel the rubber back with your finger and open it to move the hook in or out. Hook the hook to the strap itself so it doesn’t catch the freight when they pull it off the hook side. Or throw the loose hook side over and they can pick the winch side or both sides. Then throw the hook over gently so the hook isn’t banging off your wagon, wheels, toolbox, lights. Push down thru the rubber and re hook.
    It works. That flap is there vs a closed opening so that you can put hooks down through to the tie bar, or the rail edge if your trailer has a deep enough one to catch purchase.
  7. Flat Earth Trucker
    4,313
    16,511
    Nov 19, 2018
    Would coating the straps with linseed oil be an impractical endeavor?
  8. Ridlingdj
    Ridlingdj Medium Load Member
    414
    562
    Dec 12, 2018
    I have been to a few good parts places and they will custom order you straps with what ever end you want and length for pretty close to the same price as others
  9. MTN Boomer
    MTN Boomer Road Train Member
    1,157
    1,960
    Feb 4, 2019
    Soak your straps in antifreeze, they wont freeze.
  10. kylefitzy
    kylefitzy Road Train Member
    4,752
    19,798
    Aug 12, 2007
    Kansas city,Mo
    Like @Ruthless said, just peal the rubber back with you hand. A lot of times I will push dow from the inside with my other hand to help get the rubber out of the way.
  11. dberset
    75
    35
    Jan 12, 2020
