wanting to eventually get into heavy haul
Discussion in 'Heavy Haul Trucking Forum' started by Bigchevy, Sep 28, 2013.
  1. Bigchevy
    Bigchevy Light Load Member
    217
    82
    Jul 29, 2013
    colorado
    As of right now i started my career in flat bed and want to work up to heavy and over size loads and want to know the best way to work up to it, i know that it takes time and exp but i want to know whats the best path to set me up for it.
  3. Oscar the KW
    Oscar the KW Going Tarpless
    12,247
    28,120
    May 19, 2011
    Work for a smaller company that does flatbed and heavy haul, work hard, be safe and in time with enough experience you will move up, be patient as things like this take time.
    Sleepy68 and Bigchevy Thank this.
  4. AZS
    AZS Honk if anything falls off
    2,912
    1,303
    Sep 30, 2010
    PHX, AZ
    a lot of time
  5. luvtotruck
    luvtotruck Road Train Member
    1,978
    1,161
    Jul 30, 2013
    Phoenix Arizona
    Work hard and keep your record clean, Stay with the same company as long as physically possible, Maybe check to see who is running flats as well as O/S and Heavy maybe they have a ;pee wee league till you get enough experience to run with the big dogs! Good Luck!
  6. Chinatown
    Chinatown Road Train Member
    77,713
    184,261
    Aug 28, 2011
    Henderson, NV & Orient
    Watkins & Shepard has a heavy haul division, but don't know if it's at their Denver terminal or not. Check the website and give them a call.
    Rinaudo Enterprise in Jacksonville, FL has hired some new CDL grads recently and trained them for heavy haul. Don't know if there's a terminal near you though.
  7. Bigchevy
    217
    82
    Jul 29, 2013
    colorado
    Thanks i think the company i work for has a over size fleet but in Washington their one company i know of in denver but got to work up to the exp level it takes.
  8. baha
    baha Road Train Member
    4,137
    2,837
    Jul 25, 2013
    ga
    start with 10 wide steel plate and go up,
  9. TripleSix
    133,260
    May I recommend an exercise to help you? In heavyhaul and OSOW, you HAVE TO be able to get your axle weights right. Sometimes cat scales are far away. You want to get the weights right the first time. So...
    I want you to practice getting your axle weights, drives and trailer even. Yes,I know that most states will give you 40k on a 10'2 spread, but we are looking past the 48 flat, you're looking ahead to the specialized trailers. When you get a big coil, load it to where everything is even.
    Next time you get to a cat scale, get the empty weight of your steers, drives and trailer axles. Find the center of the trailer to load. The rest I will leave to you to figure out.
    milskired, baha and Bigchevy Thank this.
  10. Bigchevy
    217
    82
    Jul 29, 2013
    colorado
    Thanks ill work on that a lot of my loads are pre loaded and dont need to weight but i will start so i can get the hang if it thanks.
  11. passingthru69
    That or he can go to ATS and do the sharecropper HH thing.
    They just fired a company driver on their personal time off. So there is now another furture lease purchase trk. coming open
