Washing the engine
Discussion in 'Trucks [ Eighteen Wheelers ]' started by DrtyDiesel, Aug 13, 2012.
  1. DrtyDiesel
    DrtyDiesel Road Train Member
    5,348
    2,598
    Feb 14, 2010
    Jacksonville, FL
    I'm detailing my Prostar today before I leave out tomorrow, My question is can I pressure wash the engine? I ask because of all the electronics and stuff that's in this truck, I don't wanna fry anything. I know its kind of a dumb question but I'd rather ask someone who knows rather than fry a company truck on my property lol.
    I will let it dry out before I start it up first.
  3. seabring
    seabring Road Train Member
    1,844
    1,883
    Apr 24, 2011
    What I have done is cover up the alternator and starter with plastic garbage bags then hit it with a degreaser. Make sure the engine is cold or the degreaser could catch fire. Then use a low pressure garden hose to rinse it . The degrease will get most of the gunk off without needing high pressure. Also be carefully around your steering colum and pitman arm , drag link etc with the pressure washer as it's easy to blow the grease out of the parts. Be carefull with pressure washers as they can do more damage than good sometimes. Also might want to cover up the ECM and any obvious wiring that could get damaged from high pressure. Low pressure won't do much damage unless you go sticking into things you shouldn't !
    DrtyDiesel Thanks this.
  4. DrtyDiesel
    5,348
    2,598
    Feb 14, 2010
    Jacksonville, FL
    Thanks, I decided not to use a pressure washer but instead a regular garden hose that has a high pressure nozzle. I wont really be using degreaser, just wanting to rinse all the sand and dirt off. Just to make it look a little better.
  5. Tank33
    Tank33 Medium Load Member
    346
    108
    Jan 10, 2009
    British Columbia
    Just try to stay away from any electrical components. Wash around whatever you can. The main culprits for dirt is usually the engine block and the oil pan anyways. Water isn't the big problem, pressurized water, is the big problem. Your engine bay is soaked with rain, and road chemicals, for days upon days sometimes, and lets not forget winter. However, none of those liquids are under pressure.
    Stay away from the ECM, large banks of wiring, the obvious things. Once you have it all nice and clean, it's a good time to check for oil/coolant leaks over the next few days.
  6. DrtyDiesel
    5,348
    2,598
    Feb 14, 2010
    Jacksonville, FL
    Thanks will do. The block is the main thing i wanted to wash anyway lol
  7. Heavyd
    Heavyd Road Train Member
    7,826
    6,275
    Feb 4, 2009
    Like the others said, just stay away from the alternator and main ECM. The connectors for sensors and other harnesses are water "resistant" at best. The pressure from a pressure washer will definitely penetrate the weather pack seals.
  8. Cat sdp
    Cat sdp . .
    21,259
    75,846
    Apr 8, 2012
    Orion's Belt
    Have fun polishing those fuel tanks! LOL
  9. DrtyDiesel
    5,348
    2,598
    Feb 14, 2010
    Jacksonville, FL
    LOL, i polished one and couldnt do the other. my dad just laughed at me. then brought his buffer out
  10. pilottravel2002
    pilottravel2002 Medium Load Member
    688
    156
    May 25, 2011
    Tucson,az
    Just cover alternator and u will be fine.
  11. DrtyDiesel
    5,348
    2,598
    Feb 14, 2010
    Jacksonville, FL
    i washed it off, it looks great now and still runs perfect
