Water leak
Discussion in 'Ask An Owner Operator' started by W_rk2hard, May 21, 2023.
  1. W_rk2hard
    W_rk2hard Bobtail Member
    6
    May 21, 2023
    I had a leak in my windshield on Semi truck and water got down through my vents. I think there might be mold down there somewhere because there is a smell and it seems to have started giving me respiratory issues. Does anyone know a company that could get in there and clean it out? I called serve pro and they said no.
    77fib77 Thanks this.
  3. Long FLD
    Long FLD Road Train Member
    12,850
    53,780
    Mar 4, 2015
    Have you tried any of the cleaners or fogger bombs for vehicle vents? Other than that you’d probably have to take everything apart and clean everything and then put it all back together.
    How often do you change out your cabin air filters? That could also be a source of funkiness.
  4. Ridgeline
    22,720
    123,260
    whats a semi?
    Semi what?
    Call a vehicle flood specialist, depending on where you are at, they will charge anywhere from $200 to $400 for a good cleaning.
    Siinman Thanks this.
  5. Rideandrepair
    17,550
    56,868
    Aug 8, 2015
    Spray some Lysol into the intake. Outside set on normal, going through each setting. Vents, floor, defrost. Then do the same spraying into the inside intake. with it set on recirculating. You can take the fan out and spray the coil with a hose, letting the water go out the drain. Other choice is to pay a shop by the hour to disassemble the dash, take hoses off and clean or replace them. That’ll be expensive. Lysol kilns everything. New fragrances available. I suggest the “fresh linen” Lol,
  6. RepoweredRookie
    RepoweredRookie Light Load Member
    158
    134
    Apr 16, 2019
    I’m going with Long FLD and changing the cabin air filter.
    Rideandrepair and Siinman Thank this.
  7. W_rk2hard
    6
    May 21, 2023
    I would love to change cabin air filter but I cannot find it on my 2000 w900L
  8. W_rk2hard
    6
    May 21, 2023
    Just spoke with Kenworth and they said my 2000 w900L did not come with cabin air filter
    Rideandrepair, Siinman and 77fib77 Thank this.
  9. AModelCat
    164,604
    Nope. Its an aftermarket accessory on most (maybe all) B cab Kenworths. If it had one added, it'd be on the side of the cab, over the inlet behind the right side air cleaner.
    If you don't have one, I recommend it if you're in the dust and dirt a lot. The dust will eat the blower motor pretty quick - year or so max they'll last.
    Goodysnap, Rideandrepair and Siinman Thank this.
  10. Ridgeline
    22,720
    123,260
    Rideandrepair and 77fib77 Thank this.
  11. 77fib77
    77fib77 Road Train Member
    11,641
    76,754
    Jul 7, 2010
    St Louis
    Lysol and an AC or dehumidifier. Open bowls of vinegar???
