Water temperature
Discussion in 'Volvo Forum' started by Bald bubba, Jun 10, 2020.
Sorry I have replaced everything from the radiator thermostat water pump everything
What are you asking? Also you are not providing enough basic information to get help.
If you get a hose and can take of air to air cooler off then tape off all tubes, and clean the back side of A/C conn. by not pulling off any lines and swinging it to side and washing off back side of it, then you can clean both sides of rad. then you may find it runs cooler for years.
Rideandrepair Thanks this. -
Use compressed air to blow the fins clean. I blow from the motor side out. Don't just slide air hose across the fins, you might bend them over.
Use short burst of air moving sideways while not blowing air.
Works better if you remove the air cooler and the A/C condenser. Clean them too.Rideandrepair Thanks this. -
Chances are, that’s the problem. Front of radiators blocked with dirt, oil, corrosion. If that doesn’t help, maybe radiators plugged up. May be time for a new one, a good flush, might buy some time.
