I just tested my three relatively new, unmodified compact CBs with a newly acquired Workman 3-P (read: cheap) watt meter and got the following results using a 50 ohm dummy load and powered at about 14vdc from my running truck:
Uniden 520XL = 1.80 watts
Cobra 19 DX IV = 2.90 watts
Midland 1001z = 2.20 watts
ASSuming the watt meter is accurate, it shows the factory settings are well below the nominal 4-watt legal limit. I'm OK with that, and I doubt getting them up to the full 4 watts would make a practical difference. I use the radios only for highway travel to get and give local traffic and road conditions. I've been happy with these radios and the three-to-five foot magnetic antennas I use with them. I remove the radios and antennas when not on the road, so this type of compact and mobile equipment is exactly what I need.
My question: Is there a case to be made for getting the CBs into a shop to achieve the 4 watt limit they were designed for? I.E., will the radios perform noticeably better with that extra watt or two, or is the benefit just theoretical?
One curious thing: I'm told the watts should go up by a factor of about four when a high-pitch screech or whistle is introduced into the microphone with the key down. When I try it with all three radios, if anything the watts go down by a decimal point or two rather than rising significantly. Any idea about what I am doing wrong with my testing for the modulation swing factor?
I will note that I want the radios to sound good rather than loud, so I don't want any "clipping" of modulation limiters or whatever Golden Screwdrivers do. I am not into the whole DXing, loud-and-proud, farting, echoing, Roger-beeping, Tarzan-screaming thing. I just want decent communications about local highway matters via simple, mobile equipment.
Again, I've been happy with what I got in terms of subjective performance. Should I be, in view of my more objective watt meter results?
Watts Up?
Discussion in 'CB Radio Forum' started by Meteorgray, Aug 13, 2017.
- Thread Status:
- Not open for further replies.
Page 1 of 4
I have the Cobra 19 and it's not a bad little radio with the stock mic.I did have it peaked & tune, what I call a peak & tune is turn modulation up, and align. It is dk 3 and modulating 8 which is not bad at all...when I purchased it was way off, but took it to Clay's in San Antonio and he got it working good...my meter which is a cheap astatic does have a forward swing and real close to a local hams meter that compared the wattage of the radio...it works a lot better now....
Cheap watt/swr meters are just that, cheap. But they should at least give you a rough idea what your radios are doing. Most cbs come from the factory running around 3 watts (roughly) and modulation at round 80%. It use to be that people didn't take their radis to a cb tech to tune it up, it was easier to buy a power mic. That's why the factories set the modulation lower. If you say audio into the mic, you should see a little forward swing on the meters needle. To see a lot of swing is using a PEP meter setting, which basically gives you a warm fuzzy feeling about your radios power, it does nothing else for you. You are using cheaper radios and antenna setup for your needs, and it sounds like your basically happy with them. I wouldn't waste any money having them beefed up power wise, but just enjoy them as they are.
Ant length can make a diff to but never hurts to fine tune any radio to make it work better..
Depends who you you let do the work.. -
The factory typically sets the deadkey and modulation low so that if the FCC picks one off the shelf, it will be within the limits of the law.
I'm guessing that the McKinley I recently purchased is probably way low. Even with the mic gain and and RF power turned wide open, it sounds very quiet on the receiving end.
If I can get by a reputable shop somewhere, I'll have it aligned and scoped. -
Thanks for the information guys. As I noted, I'm happy with my ability to communicate on the road with my factory-grade junk. But I just had to have a meter to see what's going on. Sometimes a guy is better off not seeing what the meters say. I think that's why they quit putting actual gauges in many cars. What you don't know won't hurt you, sometimes.
Ya, I've heard that for years, I wonder if it wasn't just a rumor put out by the FCC. It just doesn't seem like the FCC has ever cared about people running too much power, or using their radios over 100% modulation. You look at the big boys on channel 6 as an example. Lots of people running export radios with 40 to 80 watts, or tech's installing fix-75's on cb radios and the FCC doesn't stop them. But I could be wrong.
Well some would say that Uniden is trying to be Fcc compliant when they introduced their new line of SMT radios ( 680,880,980) most , if not all , generally came stock with 3 watt carrier and 10 watt pep and not too many tuning pots to increase those values, however Ive been running stock 980 going on 2 years and it shows 3.5 carrier with 10 to 12 watt pep and does just fine on the airwaves, those numbers are comparable to old school 148's or Grants ( that werent molested) and I believe most are in agreement that both those radios were awesome.
bored silly Thanks this. -
Please dont tell me you just got a cheap advertising plug in that post.
They aren't going to go after Billy Joe Bob and his 500 watt kicker because there's no money to be had there. But if Uniden was to let a bunch slip out with 5 watts AM... cha-ching!
I have a feeling the FCC is putting pressure on even the independent dealers over the Anytone AT-6666 like I have in my car. Most likely because it's a few button presses to unlock 11 meters and presto, you've got a 60 watt radio. You can't find hardly anyone that sells them, online or otherwise.Blaskowitz, MarkH129 and wolverine11 Thank this.
Page 1 of 4
- Thread Status:
