weight
Discussion in 'Hazmat Trucking Forum' started by tattoo12, Nov 25, 2018.
  1. tattoo12
    tattoo12 Bobtail Member
    Nov 25, 2018
    I drive for a local company I haul transmix my question how much does 8000 gallons weigh ?
  3. Roberts450
    Roberts450 Road Train Member
    2,237
    3,638
    Feb 6, 2016
    8000 gallons of what?
  4. Just passing by
    Just passing by Road Train Member
    1,176
    3,140
    Feb 25, 2017
    Roberts450 and tattoo12 Thank this.
  5. ZVar
    ZVar Road Train Member
    10,911
    23,833
    Sep 10, 2010
    Flint, MI
    You can guess about 8 lbs per gallon. The real answer is not one anyone here can answer though. The reason is what is in the transmix? Is it gas and diesel? Is it gas and kerosine? Is it.....?
    Even known the products, what is the percentage of each?
    Then temperature matters. Colder weighs more as it gets slightly more dense....
  6. tattoo12
    Nov 25, 2018
    all I know it's transmix . Idk what percentage is what
  7. Just passing by
    1,176
    3,140
    Feb 25, 2017
    I am not familiar with the product but would think you'll need to scale empty and loaded a couple of times before a "guesstimate" can happen...
  8. Ridgeline
    22,720
    123,244
    Transmix comes out to according to my email about it from Kinder, 7.8 lbs per gallon.
    Edit - that is gas, Diesel, Fuel Oil, other hydrocarbon componets like Touline and "octane".
  9. thelushlarry
    thelushlarry Road Train Member
    3,023
    9,002
    Jan 9, 2012
    glasgow ky
    I know 8000 gallons weighs more than 7999 gallons and less than 8001 gallons. Hope this helps.
  10. MACK E-6
    50,008
    238,044
    Depends on the density of the liquid. Flammables like brake cleaner tend to be light while corrosives are often heavier.
    Vaping fluid on the other hand, assuming some if my past BOLs were correct, comes out to around 12 lbs or so a gallon.
  11. GasHauler
    6,257
    4,365
    Oct 23, 2005
    Vegas/Jersey
    Gasoline is even at 60° and diesel is heavier. So temp. is what you watch. Know how much 8000 or even 8500 gallons weigh. You can find that information from the pipeline-terminal or even in the library. However, I don't believe 8000 gallons of transmix is going to put you over. The truck you haul this transmix is set-up for petroleum? If your truck is heavy to start with you might want to scale the load. Now that we are just going into winter I assume that your truck is not too cold and heavy.
