Weird light issue. Need help please
Discussion in 'Heavy Duty Diesel Truck Mechanics Forum' started by Gix1k, Jan 25, 2024.
  1. Gix1k
    Gix1k Medium Load Member
    373
    586
    Dec 11, 2019
    We tried a tester today to verify the polarity and it’s not reversed. Nothing we did would get the new lights to come on using the very connectors other strobe lights are currently using. It makes absolutely no sense.
    No idea what to do now.
    Ky Flash and Oxbow Thank this.
  3. AModelCat
    163,894
    This a truck built somewhere between the mid 2000s and now? Could be the new lights are drawing such low current that the body controller doesn't recognize there are lights connected.
    Another possibility is what voltage are the lights?
    Oxbow Thanks this.
  4. skallagrime
    skallagrime Road Train Member
    3,855
    9,927
    Apr 10, 2012
    Indiana
    Check current and voltage at the connection, may be too low and your new lights dont like it
    Pita but could just run a new circuit there...
    Oxbow Thanks this.
  5. Oxbow
    Oxbow Road Train Member
    13,598
    140,872
    Nov 24, 2015
    Also, check that there is not excess dialectric gell on the connections. I have installed new led lights and have had to clean the connections to get them to work.
    skallagrime Thanks this.
  6. Gix1k
    373
    586
    Dec 11, 2019
    It's a 2019 Freightliner. These are the lights I bought.
  7. Gix1k
    373
    586
    Dec 11, 2019
    I’ll take a meter over tomorrow and check the voltage. It’s a dump truck and the wires are ran through the body, so redoing the wires would definitely be a PITA.
  8. AModelCat
    163,894
    What were you using to test the polarity of the plug in the truck? Multimeter or test light?
  9. Gix1k
    373
    586
    Dec 11, 2019
    Test light. Red one way, green the other.
    Oxbow Thanks this.
  10. Inderjit
    Inderjit Heavy Load Member
    767
    732
    Sep 17, 2017
    Most low output LED lights have a bridge rectifier on the input which will convert AC to DC and no matter which way the power is connected it will route the polarity to the correct input.
    I would check the voltage at the lights that are not working with them all connected to the circuit. With multiple lights in the circuit there will be splices in the harness and one may be failing due to corrosion. The new lights may be drawing slightly more power than the old lights causing a larger voltage drop. The light that had some LED's out was probably the last light on the harness.
  11. Gix1k
    373
    586
    Dec 11, 2019
    Ok you’re suggesting I go ahead and connect all six of the new ones or at least disconnect all the old lights and connect one new light to the line?
