western route
Discussion in 'Experienced Truckers' Advice' started by guru23231, Sep 27, 2013.
  1. guru23231
    guru23231 Light Load Member
    53
    Sep 27, 2013
    Seattle, WA
    hello , i well be taking a new route this fall , i been in the west-coast Seattle to Cali. my new route is Seattle to taxes , through Boise id n Denver Colorado and then down to Texas. how is this route , well i get good fuel mileage. thank you
  3. snowwy
    snowwy Road Train Member
    20,611
    13,326
    Jul 6, 2009
    long and boring. make sure you gets plenty of sleep cuz there's not a lot of parking for long stretches.
    guru23231 and unloader Thank this.
  4. gbrown
    gbrown Light Load Member
    55
    8
    Jul 25, 2011
    riverside ca
    lots of hill and lots of wind. your fuel mileage will suffer a bit but u will be fine
    guru23231 Thanks this.
  5. xiipercent
    xiipercent Medium Load Member
    456
    129
    Mar 19, 2007
    Go thru Moab. Better views, more fun, and shorter(miles)
    guru23231 and Dieselwrangler Thank this.
  6. Freightlinerbob
    Freightlinerbob Road Train Member
    2,234
    1,316
    Jan 15, 2012
    West Coast B.C.
    I usually go through Billings, Limon, Dumas, to avoid Oregon road tax. A few miles further but a savings IMO. Lots of wind either way.
    guru23231 and Hammer166 Thank this.
  7. Lepton1
    Lepton1 Road Train Member
    12,647
    25,589
    Nov 23, 2012
    Yukon, OK
    If this is going to be a regular run through the winter months you will likely need to change your route depending on weather and road conditions. Normally I'd run through Pendleton down to Ogden, take the I-84 bypass to I-80, then catch I-25 and select your best route from there (depending on which area of Texas you are going). Moab (as noted above) may be better if the eastern slopes of the Rockies are getting hammered, running down to catch the I-40. I ran the I-40 LA to Amarillo all last winter and only dealt with snow once.
    Wind will be the ongoing factor that will make or break your profits running any of those routes. During winter I frequently consult the wind map at weather.com if I have a decision regarding routing or timing of a run that might be impacted by current wind conditions.
  8. guru23231
    53
    Sep 27, 2013
    Seattle, WA
  9. STexan
    STexan Road Train Member
    14,963
    29,160
    Oct 3, 2011
    Longview, TX
    Barring isolated weather systems, I too would go through Price, Moab and Albuquerque unless I had to go through Denver. I can't see that there would be a nickles worth of difference either way as far as elevation rises but you could look at Google Earth to run an elevation analysis on the routes.
  10. snowwy
    20,611
    13,326
    Jul 6, 2009
    as long as he stayed off the 70 going into denver. should he decide that route for whatever reason. them 2 passes are 10,500 and 11,000 feet. and a lot of curves. one of the suckiest stretches of highway in america to be on.
  11. Hammer166
    7,601
    27,764
    Aug 18, 2007
    ~8600+' and loving it!
    I ran the NW out of Amarillo for 10+ years. I-90 is definitely the way to go if you're going non-stop. And if you need to go south, then Moab, Farmington, and 550 over to Albuquerque rather than down thru Gallup.
