Western star AC problems
Discussion in 'Car Hauler and Auto Carrier Trucking Forum' started by Jcurran90, Jun 10, 2017.
  1. Jcurran90
    Jcurran90 Light Load Member
    53
    8
    Apr 29, 2016
    I have a 2007 western star 4900 the aC and heat only come out the floor and defroster anyone have a answer to this getting hot out and going to need that cold aC blowing out the vents ????
  3. SLANT6
    SLANT6 Road Train Member
    1,094
    1,376
    Dec 3, 2012
    The Nut House
    I do not know specific to your truck, however just about all A/C works off the same principle. There is a door or duct in the dash either stuck open, closed or broken preventing air flowing to the vents.
    Hammer166 Thanks this.
  4. Jcurran90
    53
    8
    Apr 29, 2016
    That's what I been reading but I can't find that door ?
  5. Hammer166
    7,590
    27,698
    Aug 18, 2007
    ~8600+' and loving it!
    I never had issues with mine, but the right lower kick panel is just push pins, and pulling the switch panel will let you see the top of the blend unit. I can't remember if the doors are air or electric on that.
  6. SLANT6
    1,094
    1,376
    Dec 3, 2012
    The Nut House
    Any competent A/C shop should be able to get you squared away. Probably could use a charge anyway. Large truck A/C is a pain from a maintenance standpoint, just from all the vibration it takes.
  7. Ridgeline
    22,700
    122,151
    You either have an air leak or a cable problem within the A/C-heater unit. Most likely an air leak. This could be a defective vent selector unit.
    Jazz1 Thanks this.
  8. Jazz1
    Jazz1 Road Train Member
    2,373
    4,971
    May 7, 2012
    Thunder Bay On
    Likely heater/ac control unit is faulty. Units are replaceable. I have run into same issue with autos and always got scrapyard unit to replace. Good luck with that.
  9. Telliott67
    Telliott67 Bobtail Member
    4
    I have a 2016 Western Star Glider, I have 58k miles on it and I’ve went through 5 AC compressors anyone else heard of this with Western Stars?
  10. Hammer166
    7,590
    27,698
    Aug 18, 2007
    What's going bad? The bearing/clutch pack or the compressor section?
    The bearing, I'd look at belt tension issues. If the clutch keeps burning up you have a wiring issue.
    If it's the compressor, you need to make sure you're flushing the system clean of debris. That includes replacing the dryer/filter/expansion valve.
