WesternStar Def pump relocation
Discussion in 'Heavy Duty Diesel Truck Mechanics Forum' started by Steezup, Sep 6, 2018.
  1. Steezup
    Steezup Bobtail Member
    Aug 29, 2018
    We are putting a lift axle on an WesternStar and the DEF pump must be relocated due to space issue.
    Is there rules for the eight of the pump compare to the DEF tank. Like does it have to be lower than the tank or we can put it higher than the tank. If higher will we have probleme drawing the DEF in the pump
  3. RicoNC
    RicoNC Light Load Member
    92
    121
    Jan 31, 2015
    Raleigh/Clayton, NC
    You can relocated the whole def system in the freaking dumpster!!!!!
    Roberts450 and Oldironfan Thank this.
  4. Crude Truckin'
    Crude Truckin' Alien Spacecraft
    2,455
    6,860
    Oct 22, 2016
    North Dakota, Eh?
    Call Western Star.
    Steezup and AModelCat Thank this.
  5. AModelCat
    164,405
    ^^^best to contact your local dealer. They likely deal with scenarios like this all the time. If you're still under warranty and have a failure they will likely kick your claim back in a heartbeat if you didn't relocate it properly.
  6. Steezup
    Aug 29, 2018
    Ok Thanks AModelCat I think that would be the best since the truck is brand new with 30 miles on it
    Crude Truckin' Thanks this.
  7. Oldironfan
    Oldironfan Road Train Member
    5,776
    5,544
    May 22, 2017
    Garbage belongs in the dumpster. Amen.
    RicoNC Thanks this.
