What CB antenna
Discussion in 'CB Radio Forum' started by TruckerPete1990, Feb 24, 2023.
  1. TruckerPete1990
    TruckerPete1990 Road Train Member
    8,623
    5,382
    Jul 16, 2012
    Bentonville Arkansas
    So I'm rewiring my ranger rci 39 hp plus. As its still using factory power and causing interference. So gonna run it down to batteries.
    Looking to upgrade my single CB antenna also as I'm running just a new firestick. What cb antenna would you recommend for a T680?
  3. Ridgeline
    22,720
    123,213
  4. TruckerPete1990
    8,623
    5,382
    Jul 16, 2012
    I've already ran a new coax like 2 years ago
  5. Night Stalker10
    Night Stalker10 Road Train Member
    1,697
    1,271
    Jun 26, 2017
    I drove a 2006 378 Peterbilt for over 10 years, and I had a Hustler FG27S 4ft antenna on it. It's a very tough antenna. The HQ27 is 55 inches tall. Another great steel mobile antenna. I believe it's rated for 250 watts.
  6. Ridgeline
    22,720
    123,213
    run new coax
  7. TruckerPete1990
    8,623
    5,382
    Jul 16, 2012
    I will be along with new ground straps. I have at homr and ill be usi so i dont have to solder K40 K4018FME 18ft Super Mini-8 CB Antenna Cable with Removable FME Connector, Black https://a.co/d/hZtZO9l
  8. Ridgeline
    22,720
    123,213
    Well go get quality cable, put proper ends on it.
    These are Chinese made cables that are marginal.
  9. TruckerPete1990
    8,623
    5,382
    Jul 16, 2012
    What brand do you recommend?
  10. Ridgeline
    22,720
    123,213
    Beldon is good, go to DX engineering and order it by the foot. They have a lot of different types to chose from. They have Time Microwave and DX engineering branded 8X for 65¢ a foot, which will work.
    The reason I say which is because you have interference (which you didn't explain what it was) and coax has something to do with the interference. Coax being a couple years old should just be changed out anyway, it is a cheap thing to rule out for any issues.
  11. TruckerPete1990
    8,623
    5,382
    Jul 16, 2012
    I think It's a ground issue to be honest. Some of my dash switch back lights go off when keying up and getting a lot of background noise so my squelch is like 1/4 atm lol
